Author Topic: Quick temp sender question - trans  (Read 1497 times)
Offline GoodysGotaCuda
« on: August 02, 2006 - 11:47:20 AM »
I have a brass fitting setup that i will be plumbing to get a trans temp reading. As it is now, there is very little space around the actual sender probe, but the base/bottom of the probe is wide open. I'm wondering if the sender probe has to be submurged in the fluid to get a good reading, or will the reading be just the same if only the bottom of the probe catches fluid at all times.
Thanks :wave:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
Re: Quick temp sender question - trans
« Reply #1 on: August 02, 2006 - 01:02:26 PM »
if the sender is like the one I had from B&M there is a 1/2" long brass section that is to be submerged in the fluid as deeply as possible. I doubt is accuracy will be affected if a 1/6 or 1/8" is uncovered tho
Offline tactransman
« Reply #2 on: August 02, 2006 - 07:33:35 PM »
Thanks :wave:
Where do you have it , in the pan?
Terry-tactransman
Union, Mo.
« Reply #3 on: August 02, 2006 - 09:32:11 PM »
It will be inline with the outlet/front cooling line.
1976 Dodge Warlock
Offline tactransman
« Reply #4 on: August 03, 2006 - 06:16:09 AM »
It should be fine. :thumbsup:
Terry-tactransman
Union, Mo.
Offline Pentastar Pete
« Reply #5 on: August 10, 2006 - 06:46:51 PM »
What should a normal temp be for an automatic trans (727) ????
74 Rallye Challenger
73 Rallye Challenger
68 Charger RT
Offline tactransman
« Reply #6 on: August 11, 2006 - 01:05:47 PM »
180 to 200 degrees.
Terry-tactransman
Union, Mo.
