Author Topic: How to change ignition switch  (Read 1868 times)
Offline Grec
« on: August 03, 2006 - 06:43:43 PM »
Basicaly, I'm completly in the dark about how this comes apart.
Any pointers on getting the steering column apart and the ignition cylinder out?
I know. It's time for to buy a shop manual. :-)
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
Re: How to change ignition switch
« Reply #1 on: August 03, 2006 - 08:06:48 PM »
what year and model of mopar?
Offline 4Cruizn
  • HEMI FISH
« Reply #2 on: August 03, 2006 - 08:19:34 PM »
This may help.   :2thumbs:
« Last Edit: August 03, 2006 - 08:22:32 PM by 4Cruizn »
Offline Grec
« Reply #3 on: August 03, 2006 - 08:38:48 PM »
Duuuuh.
She's a '73 Challenger Rallye. 4 on the floor.
- 440 Six Pack
« Reply #4 on: August 04, 2006 - 12:10:09 AM »
pull the wheel & crush can , then remove the lock plate & there is a plate that holds the lock lever in place remove that & below it is a push pin that retains the lock cyl
Offline Grec
« Reply #5 on: August 04, 2006 - 08:13:01 AM »
Gotcha.
Thanks, guys.
- 440 Six Pack
Offline Grec
« Reply #6 on: August 04, 2006 - 05:16:02 PM »
OK, got as far as the crush can and I got stuck. D'oh!
I removed the large bolt in the center expecting the can to just come right off. Nope.
Figured I would ask before I began pulling on things and break something.
What else besides that bolt is holding the can on?
- 440 Six Pack
Offline duodec
« Reply #7 on: August 04, 2006 - 10:17:11 PM »
A very tight spline fit.  You need a steering wheel /hub puller.  Its available at most generic and good parts stores.  Don't try to muscle or pry the can off, you'll just damage it.
« Reply #8 on: August 05, 2006 - 12:03:30 AM »
I had to modify my puller with a longer center bolt & 3/8 bolts to remove the can
Offline Aussie Challenger
« Reply #9 on: August 12, 2006 - 08:48:31 AM »
My '70 Challenger was a column auto but somebody has installed a floor mounted slapstick. I may need to replace the column or at least the upper parts. What if any other MOPAR product steering column can be interchanged with this? :clueless:  Thanks in advance. While on the interchangability theme what other headlight switch & wiper switch can be used? Not sure if it is a 3 or 2 speed wiper at this time.
« Last Edit: August 12, 2006 - 08:52:33 AM by Aussie Challenger »
