Author Topic: help with k-frames  (Read 1574 times)
Offline bullfrawgs
  • I'm a llama!
help with k-frames
« on: June 09, 2003 - 10:25:58 AM »
I have a 73-challenger 318 with a k-frame that has been hit and has a huge dent. I want to replace it. I have found a guy that has a big block k-frame with sway bar and control arms. Is there any difference that i should be aware of before i buy it? Are the engine mounts the same or would i need special mounts to bolt my small block to a big block k-frame?
Re:help with k-frames
« Reply #1 on: June 09, 2003 - 01:35:13 PM »
if the K Frame is from an E body it is identical , if it is frome a 71-72 B body it is also identical
