Author Topic: Need fender tag info for that 74 portholed cuda!  (Read 4174 times)
Offline rr74cuda
« on: August 04, 2006 - 08:57:34 AM »
Help with 74 cuda fender tag codes. Still trying to decode the tag on this portholed cuda and was hoping for some enlightenment! Top of tag fourth character on right is L2.Top of tag fifth character on right is 835. Third line from the top first character is G64. Third line from top second character is 674. So far I have determined that this car was Frosty green metallic with a white vinyl top and a white side stripe. The interior code is A6XW which I thought was white seats,door panels and headliner.  Came back as black on the decoder I used. Anyway  any help is appreciated because the wife has given me Carte Blanche to restore this car back to original!  :woohoo:
Offline EvilTwinATX
Re: Need fender tag info for that 74 portholed cuda!
« Reply #1 on: August 04, 2006 - 09:15:05 AM »
 :wow: You are a lucky man my friend.... but you shouldn't worry about putting the car back to original if it is a 318 or 6 cyl. .....tell her it is a HEMI ( :roflsmiley:) and GO TO TOWN!!!  :2thumbs:
Offline 360 'CUDA
« Reply #2 on: August 04, 2006 - 11:15:50 AM »
You need to get a new decoder.  That is definitly an original White interior car and I can't believe someone took a green car and painted it burnished red metallic.    (brown)
The reason I know is yours is optioned the same way my white car was when it was new except mine didn't have a vinyl top
 Can you post the fender tag?  Just cross out the VIN number.
« Last Edit: August 04, 2006 - 11:26:12 AM by 'CUDA360 »
Offline rr74cuda
« Reply #3 on: August 05, 2006 - 09:03:42 AM »
HERE IS THE FENDER TAG
N85 R11 V6W L2 835
M25 M26 M31 M88 N76
G64 674 J25 J52 J54 M21
V1W U B41 C56 G11 G54
KG2 A6XW 000 A23 329816
E44 D34 BS23 G4B ------
 :1zhelp:
Offline 360 'CUDA
« Reply #4 on: August 05, 2006 - 11:09:59 AM »
R11  AM Radio
V6W white tape stripe
L2
835
M25 sill molding
M26 wheel lip molding
M31 belt molding
M88 decklid molding
N76 coolant recovery system
G64 rightside chrome racing mirror
E44 318 2bbl
674
J25 3 spd wiper
J52 inside hood release
J54 sport hood
M21 roof drip molding
V1W full vinyl roof white
U
B41 front disc brakes with 11 inch rear drum
C56 bucket seat
G11 tinted glass
G54 left outside mirror remote chrome race
KG2 frosty green metallic
A6XW white interior
000
A23  Decor package C...
floor shift, cigar lighter, drip rail mouldings, wheel lip mouldings, belt mouldings, black tape treatment between taillights, vinyl trim
329816 vehicle order number
E44 318 2bbl
D34 torqueflite 904
BS23 'CUDA hardtop
G 318
4  1974
B  Hamtramck
Nothing about port hole windows.  You are right about the frosty green metallic but are you seeing Green paint peeking out here and there??
Offline rr74cuda
« Reply #5 on: August 05, 2006 - 10:06:17 PM »
The inside of the trunk is still the original color as is deep in the door jambs. The person that painted it was pretty thorough including spraying most of the engine bay but the original frosty metallic is still apparent low on the firewall etc.  A local mopar guru says he knows of two other E body cars locally that had porthole windows in them. One Chally that the original owner says were installed by the dealer. :dunno: The windows on this car are supposedly more round than mine. The other I did not get too much info about. I see you didn't have much more luck than me when it came to a few of those codes, hopefully I can get them all so as to return this car to original. THANKS! Rob. :biggrin:
Alaskan_TA
« Reply #6 on: August 05, 2006 - 10:45:20 PM »
Additional info, one question and one correction;
L2 - Assembly line two
835 ?
674 - Can you look at this one again? It should begin with a letter.
U - Build for US sale
000 - Upper door frame paint - None
A23  Decor package C... Correction, A23 in this postition is the Sheduled Production Date, October 23rd 1973 (1974 model year)
If possible when asking for a decode, post a photo, it helps us help you.  :thumbsup:
T/Ake care,
Barry
Offline rr74cuda
« Reply #7 on: August 07, 2006 - 12:55:23 PM »
Evil your post gave both the wife and I a hearty guffaw! :lol: She has been around me too long and knows what a Hemi looks like. But in the spirit of things maybe I will give it a shot. AlaskanTA I am fairly sure that those numbers are correct, but I will look again after I prop up my peach tree which is resting firmly across the hood right now.(bumper crop this year) I was busy this weekend looking at a 392 hemi which I thought would look good in my 65 Satellite. If it will fit.
