Author Topic: Fitting 73 Cuda Woodgrain Decal ?  (Read 1063 times)
Offline Eurocuda
    • Chronos Engineering Supplies
« on: August 05, 2006 - 05:16:00 AM »
Hi
I have been given a 2 piece adhesive decal kit for my Cuda - minus he instructions. I have heard that these are hard to get right? Any instructions tipe etc ould be most appreciated!
Thanks
Mark
Offline HemiOrange70
Re: Fitting 73 Cuda Woodgrain Decal ?
« Reply #1 on: August 05, 2006 - 01:34:15 PM »
When applying the decals, spray winddex on the dash, this allows you time to move the decals befire they adhere. Press the decal on with a papertowel and let the windex evaporate
Offline Eurocuda
« Reply #2 on: August 05, 2006 - 04:07:59 PM »
Thanks- whats windex?- Im in England  It may ahve another name here
Thank
Mark
« Reply #3 on: August 05, 2006 - 04:16:57 PM »
Window cleaner
Offline Eurocuda
« Reply #4 on: August 05, 2006 - 04:41:05 PM »
Ah- Ok thanks
Do I stick it over the existing wood grain or and try and remove the original- sorry if this is a dumb question but the original looks tricky to take off
« Reply #5 on: August 05, 2006 - 04:47:12 PM »
You can put it over the original. Trying to get the old stuff off, is TRUELY a pain. Also, if you use a harsh chemical to remove it, you might tarnish the metal trim.
Offline Eurocuda
« Reply #6 on: August 06, 2006 - 02:10:59 AM »
Hmmm
not sure if I brave enough to try it as my original is not so bad- a couple of scratches thats all. It may be best left as is. Is there any other solutions?- Did i read about complete replacement metal plates somewhere?
« Reply #7 on: August 06, 2006 - 04:59:08 AM »
Hmmm
Yes, you can get the replacement metal plates. I did that, but they aren't cheap. I think about $169.  :clueless:
