Author Topic: 2007 Calendar Entry Information (35 Qualified Submissions)  (Read 28419 times)
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
Re: 2007 Calendar Entry Information (24 Qualified Submissions)
« Reply #90 on: August 29, 2006 - 07:18:01 PM »
I didn't know I could do that since it was used last year.  But my whole front end is different now so it wouldn't quite be accurate, I don't know if that matters but let me think about it.
It really only matters for those whose car was printed in the calendar.  Just let me know...I believe I still have it.
Offline ROMI
  • 71 Challenger R/T 340 4 speed, Lapeer Michigan
« Reply #91 on: August 29, 2006 - 07:22:41 PM »
Thanks REV !
Offline gomopar440
« Reply #92 on: August 30, 2006 - 07:55:28 AM »
Does the car have to be finished? I think it would look cool to see some of the projects in there that some people are working on you know to kinda show encouragment(sp).....
That'd be the only way I could get my car in the running here. Maybe this pic would be good for the spare spaces on the calendar. :dunno: A messy shop is a happy shop right? :D
Anyway, here's the latest shot of mine in it's present state. I just got it drivable on this last trip to PA and finally got to drive it around the yard for the first time since I've owned it. Right after that first drive I started mounting the fiberglass fenders (gave up on waiting for the steel GoodOffTheMark fenders :-\ )and the T/A hood. It's originally a Black car with an Ember Gold interior. I had originally thought it was just a very dirty white/cream interior. :clueless:
FWIW I'll let you guys decide if it would be worth putting up. I'm at work now and only have the low res version here. I have a 3MP high res shot of this at home if needed.
« Last Edit: August 30, 2006 - 08:01:14 AM by gomopar440 »
Offline Rev-It-Up
  • Global Moderator
Re: 2007 Calendar Entry Information (26 Qualified Submissions)
« Reply #93 on: August 30, 2006 - 09:00:10 AM »
Right now we have 2 cars submitted that are unfinished projects.  You are welcome to join in the fun!  Just send it to me by midnight.
Offline tactransman
Re: 2007 Calendar Entry Information (27 Qualified Submissions)
« Reply #94 on: August 30, 2006 - 09:40:11 AM »
Maybe Rev will make us an "Unfinished Cars" calender.  :smilielol:  :smilielol:  :smilielol:
Terry-tactransman
Union, Mo.
Offline Carlwalski
« Reply #95 on: August 30, 2006 - 09:48:00 AM »
Sorry to butt in, Go-Mopar, I notice a T/A hood on your Challenger. Is it a steel hood? If so/not what's the fit and quality like? Also, where did you purchase it and were there many modifications needed to snug it in?
Thanks.  :cheers:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Rev-It-Up
  • Global Moderator
« Reply #96 on: August 30, 2006 - 09:54:23 AM »
Not a bad idea.  In the past I've kicked around the idea of other calendars we could do....
Best of the Babe Section (We'd have to be careful where we get the pics from!)
The Wives of CC.com (You guys take pics of your wives with your cars...or our female members)
Before and after Pics (Side by side before and after pics of your cars)
CC.com Friends (Members cars pictured together)
Just some thoughts.
Offline gomopar440
« Reply #97 on: August 30, 2006 - 10:57:07 AM »
Thanks.  :cheers:
NZ, No I didn't go with the steel T/A hood. It's a bolt-on fiberglass repop from Unlimited Products. So far the fit is hard to say since I've replaced the fenders with fiberglass pieces all at the same time. All the pieces are just being adjusted together to line up properly. Overall I'd say it's pretty good hood though. It is a bit rough around the scoop opening but that can be cleaned up without too much trouble. Added some pics of it for you below :)  I don't have the pins to hold it down so the front spring is holding it up a little bit right now.
The main reason I used fiberglass was weight savings. I am removing as much weight as possible up front to try and balance out the weight distribution for better handling. When the 512 wedge replaces the original 318 in there I'll need to reduce any extra weight wherever I can. The whole top end of the engine is aluminum (Indy) on the RB. Future plans are to also relocate the battery to the trunk at the time I do the engine swap. The starter and alternator are late model (ie: light weight) pieces from a Dakota. The water pump housing is aluminum and the pump itself is a CSR electric bolt in unit. I'll be using a pair of large shrouded electric fans on an aluminum radiator for cooling. I've got a bunch more info on the car over on my Moparnuts thread if you want to check it out... http://www.moparnuts.com/forums/showthread.php?t=3636  There's plenty of pics and info all about the whole project in there. It's kinda long though with 244 posts in the thread already. :dogpile:
« Last Edit: August 30, 2006 - 11:07:54 AM by gomopar440 »
Offline GoodysGotaCuda
« Reply #98 on: August 30, 2006 - 11:03:21 AM »
Just some thoughts.
Young Guns.  :naughty:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Rev-It-Up
  • Global Moderator
Re: 2007 Calendar Entry Information (30 Qualified Submissions)
« Reply #100 on: August 30, 2006 - 04:22:45 PM »
OMG!!!
  I can't believe April just entered!!   :scared:  :scared:  :scared:
Offline Rev-It-Up
  • Global Moderator
« Reply #101 on: August 30, 2006 - 04:28:20 PM »
OMG!!!
Are you getting a little nervous Mike??  :roflsmiley: :roflsmiley:    I think there are a couple more people trying to get their pics to me tonight.
BTW...I'll be out until 9:30 tonight so if anyone sends me something...I'll get back with you after 9:30.  Don't panic!
« Reply #102 on: August 30, 2006 - 04:30:54 PM »
Did you say panic??  Yes, I am in a panic!!   :hyper: There were only seven other entries when I submitted mine!   :crying:
Offline Rev-It-Up
  • Global Moderator
« Reply #103 on: August 30, 2006 - 04:33:18 PM »
I have to admit, I was a little concerned with the small amount of submissions in the beginning.  Looking pretty good right now.  Last year we had 24 submissions so you had a 50% chance of getting in the calendar.  The percentage is going down now....
« Reply #104 on: August 30, 2006 - 04:34:49 PM »
... Umm, yes, I noticed that.   :bricks1:  :bricks1:  :bricks1:
