Project Axle Swap proceeds apace, but I've got a few questions on leaf springs.
1) Most importantly, they both look the same to me, but I know there are left and right springs. Since I've got to put the shock plates and sway bar plates on them, how can I tell which one is right and which one is left?
2) Speaking of the sway bar plates, same question (these came from a parts car, else I would have marked them when they came off). They might be the same, but just from eyeballing them they look a little different. If they are, which is right and which is left?
3) Finally, the sway bar plates have a bolt to go through the center of the leaf springs. I'm assuming that I should remove the bolt that is in them (after clamping them together) and use the bolt that is in the sway bar plates, correct?
As always, thanks for the help.
