Author Topic: 73 Challenger Dash Lights & Gages  (Read 12746 times)
Offline kingtroll
Re: 73 Challenger Dash Lights & Gages
« Reply #15 on: August 14, 2006 - 09:23:52 PM »
Try looking to see if your wiring connections are grounded. I had the same problem with my Cuda and my mechanic told me who ever did my wiring didn't ground properly. MY gauges worked but I had no lights in the dash at night so my dimmer switch wouldn't work because the lights must work for the dimmer to work.
Good luck and I hope this helps
1974 Barracuda
Offline DMZ73
    • http://www.pbase.com/dmz73/
« Reply #16 on: August 15, 2006 - 08:22:55 AM »
My frined Gian had the same problem. It turned out to be  aground. I will ask him today what he forund. Check the ground to your ignition box. Check your ground wire to your cluster.
Troubleshoot-
What was the last part/parts replaced/removed prior to painting. My friend tells me that its as simple as celaning off/removing the paint and putting red axle grease on the ground.
Dan
Offline Robby
  • Newbie
« Reply #17 on: June 21, 2011 - 02:25:41 PM »
Hi everyone,
I am new to this site. I have a 1973 Dodge Challenger. The dash dimmer switch is no good and I can not find one. I do not know how to fix the problem. The car was rewired by someone else and does not have the original colored wires. I am at a loss as to what to do. I also need the bulbs there are 3 kinds do not know which ones they are. Hope someone can help?
Thanks, Robby
« Reply #18 on: June 21, 2011 - 08:42:31 PM »
Hi everyone,
Thanks, Robby
Welcome Robby,  We are fortunate to have a forum member, Slotts, that restores dash dimmer switches and other switches components , these are not available new and anything used may be in no better shape than what you have. Check the following link
http://www.cuda-challenger.com/cc/index.php?topic=64880.0
In the mean time you can fashion a jumper using a mini-fuse to bypass the switch &  power your instrument lamps. BTW the light bar must be grounded to the dash frame to work.
You say the car was re-wired, did they use a stock harness and just splice or was it a complete re-wire?
Here are some basic wiring diagrams but without the colors to go by you just have to trace with a meter.
http://www.mymopar.com/72to76_wiring.htm
Bulbs can be looked up on-line at most any parts store.
http://www.autozone.com/autozone/parts/1973-Dodge-Challenger/Electrical-and-Lighting/_/N-ip5n6Z9encv
« Last Edit: June 21, 2011 - 08:44:24 PM by Bullitt- »
