Added rear sway bar.
Author Topic: Added rear sway bar.  (Read 500 times)
Offline torredcuda
  • Epping NH joined 11/23/03
« on: August 06, 2006 - 04:40:06 AM »
Finally installed the rear sway bar on the `72 that I`ve had for a bunch of years.I was kinda afraid of having clearance issues with the custom bent exhaust but after taking out the lower shock bolts I was able to wiggle it into place no problem.Last night I took it out to a criuse night and really noticed the difference.The back of the car is much more solid feeling and doesn`t lean as much(DUH!) and handling is much more neutral where as before it would understeer.I also did a traction test at a stop light but it lit `em up about the same as before!  :burnout:  :bigsmile:
I also had to repaint the rear spoiler due to some voids in the fiberglass popping thru and decided to paint it body color instead of black.
 :useless:
I`ll get some pics later today and see if you guys think it looks better flat black or Tor-Red.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Oldschool
Re: Added rear sway bar.
« Reply #1 on: August 06, 2006 - 09:38:00 AM »
  :2thumbs:   :thumbsup:   :ylsuper:
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« Reply #2 on: August 06, 2006 - 02:30:49 PM »
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
