A quick tip, providing you have not bought a spacer yet, is to take 4 sockets, 1" in length, sit them on the intake, and put your carb and air cleaner assembly on it, and slowly close the hood, trying to keep an eye on hood clearance as you close the hood, if you can close the hood with out anything hitting, raise it back up, and set another socket on top of the air cleaner, and see if that clears, if it does, chances are, you have plenty of room for a 1", I had to do this with my '69 Charger R/T with 440.... I did the 1" socket on top to try and compensate for engine movement.....
