Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Hood Clearance Issues
« previous
next »
Print
Pages: [
1
Author
Topic: Hood Clearance Issues (Read 626 times)
hookem78613
Jr. Member
on:
August 06, 2006 - 09:13:43 PM »
I would like to see if anyone has any intake setups that worked on a Charger. I am running a 500 CI Wedge Crate motor in a 68 Charger. I have stage VI heads and was running a adapter plates with a dual plane intake, 870 street avenger and a 3" K&N Filter with a drop base (2.5 inches carb flange to top). This fits but I want to go with the M1 intake I have. I have the M1 milled a bit off the top and it's exactly 1" taller than the previous setup. To be safe I wanted to keep the same height. Since the motor is out of the car now I can't do any measurements but I thought I would see if I someone has any recommendations so i can slam it in and go!
Hookem!
Logged
74 Barracuda Drag Car - Big Block /727
68 Charger R/T - 440 Stroker / 727
EvilTwinATX
Full Member
Re: Hood Clearance Issues
Reply #1 on:
August 06, 2006 - 09:45:52 PM »
forgot to post this question for you hookem...
oops....
Hope you figure out your clearence issues.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
August 07, 2006 - 12:25:27 AM »
with only 1.5" to the hood you may restrict air flow into the carb & negate any gains , you will need a drop base filter & probably a 3 " element , Chargers are tough with no factory raised hoods available
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
