Author Topic: Air Filter for 440  (Read 546 times)
Offline MR291
Air Filter for 440
« on: August 07, 2006 - 02:25:06 PM »
Hi,
I am looking at a K&N X-Stream air filter assembly for my 440 Cuda.
I am going to keep my snorkle air cleaner for shows, but I need something a bit more efficient for daily driving.  Has anyone tried these and are there any recommendations as to which one is best for height and diameter.
Thanks.
Jerry
Re: Air Filter for 440
« Reply #1 on: August 07, 2006 - 04:25:15 PM »
I have one on my 440. I have a flat hood, so I went with the drop-down assembly.
« Reply #2 on: August 07, 2006 - 04:29:14 PM »
the X treme works well
Offline EVIL72
« Reply #3 on: August 07, 2006 - 07:20:40 PM »
 I got an 14" XStream top. Works great! Get the drop down base, your going to need all the clearance you can get. I use the K&N drop down base.
 Can't help ya with filter height because I run a small block.
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Offline zerfetzen
  • 'Cuda, should'a, would'a...you lost.
« Reply #4 on: August 09, 2006 - 07:37:06 AM »
K&N's website has a calculation for air filter size.  I'm guessing you'll need bigger.  I can't remember the dimensions of mine (am at work right now), but think I went with about 4" tall and 14" diameter?  Hope I'm not way off.  The main thing I remember was that a little increase in height gets you more volume than a little increase in diameter.  I hope the XStream works well for you.  Cheers.
