best carb for 340?
Author Topic: best carb for 340?  (Read 21466 times)
Offline Dragula
Re: best carb for 340?
« Reply #15 on: August 25, 2006 - 11:46:09 PM »
A 340 is a little touchy with a holley 750dp, and easy to flood, but they are the right choice for all out performance. Now you say you like the 600 eddy, I have a 625 carter on mine for about 3 more days. I have raced 340's for many years, and they will take up to an 850cfm dp holley if built correctly. Now there are a four things that you should consider when choosing a carb for a 340
First, anything less than a 750cfm will limit your upper end horsepower somewhat, especially with a single plane intake. If your not shifting it at 6000-6500 every weekend and your running a dual plane intake, then the easier tunability of a smaller carb is for you.
Two, the torque converter plays a major roll in where the power hits. If your lugging the engine down with a stock converter, a big carb isn't going to function as well at lower rpms because the signal to the boosters doesn't get going till its above 2500 or so. When you run a +3000 stall convertor, all the low end stumble tends to go away instantly. So real mild or stock convertor and big carb, not a good mix. UNLESS you go the route I am on Monday with the NEW annular booster venturi style 750dp. This will allow the carb to be sensative enough with the fuel metering to let you lug it all the way down to 2200-2300rpm like a small carb, yet have the big top end charge of the big boys....
Three, the eddy style carbs do not supply enough fuel shot under acceleration to make a 340 happy. A 340 likes a big fuel shot. I have modified enough of the eddy style carbs to know that they idle great, get good milage, have great street manners, and go lean the minuit you lay into it, and then gradually climb out of it as the jets take over. Now if your just running a stock cam and intake, you might not notice it as much, but when you get up into even a mild performance cam, intake, and headers, its noticable compared to the snap of a good running carb.
Forth, to take full advantage of the bigger carb, you need a quick advance distributer on the 340. Without it, it will tend to load up a lot easier, and it will not want as much fuel. I HIGHLY reccomend the quick advance distributer on any 340, stock or modified. It is the single biggest bang for the buck, and is what really lets the big carb work well on the 340. If you ain't running one, I wouldn't bother putting the 750 on it.
Just in case your curious about the carb I went with, its a Quick Fuel Technologies 750DP with annular boosters. It flows well over 800cfm, and its going on my mild 360 with a dual plane air gap, and at present, stock converter, headers, and oooh yah, quick advance distributer set at 39*. The plan is in the very near future to put a new trans in I have, but haven't rebuilt yet with a 3000 converter. When I get this little nasty right, your going to see a mild 1/2 ton pick-up running 11's with a small block and then go cruisen..
« Last Edit: August 25, 2006 - 11:54:19 PM by dragula »
Offline 70 340
« Reply #16 on: August 27, 2006 - 08:40:53 PM »
Sorry for being stupid but what is a quick advance distrbutor.Does the mopar performance electonic ign dist have quick advance?
Offline Dragula
« Reply #17 on: August 27, 2006 - 10:27:17 PM »
Mopar sells them typically with a vacuum pod. I always run without the vacuum advance and just remove the pod. A stock mopar distributer that came with your car is holding it back big time. You want one of these:
http://chucker54.stores.yahoo.net/vacadeldis.html :drool:
They make a big difference
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
« Reply #18 on: August 27, 2006 - 11:41:34 PM »
Had a holley street avenger 670 on my 340 4spd...ran great.
Offline Dragula
« Reply #19 on: August 28, 2006 - 03:13:27 PM »
Got my NEW main body from Quick Fuel today :cooldancing: and built me a new carb with it. Now I have a 750DP that flows about 800cfm and has annular boosters for better fuel control.
« Last Edit: August 28, 2006 - 03:20:41 PM by dragula »
« Reply #20 on: August 28, 2006 - 03:53:11 PM »
That looks SWEEET!!   :droolingbounce:
« Reply #21 on: August 28, 2006 - 11:54:22 PM »
how do you stop the advance palte moving inside the dist with the vacuum pot removed Dragula ?
 I would be interested in feedback from the quick fuel carb conversion , it should work great with annular boosters  :2thumbs:
Offline Dragula
« Reply #22 on: August 29, 2006 - 12:12:08 AM »
1. Sheet metal screw installed before removing the pod, or just a pre-drilled hole, then remove the pod, install small sheet metal screw. You did forget to ask about the small tab that locks the cap from rotating that was attached to the pod....
2. The annular boosters will get it to respond like a smaller carb. Typically when employed on a 1050cfm carb, it respods like an 820-850cfm carb, but with leg room.
« Reply #23 on: August 29, 2006 - 12:16:54 AM »
there are a few ways to provide the tab for the cap . lean burn dist donor for example
that is wht I have found too with annulars , just never used a Quickfuel body yet
Offline Gurragas of Sweden
    • Restorers
« Reply #24 on: August 29, 2006 - 04:44:31 AM »
I run a 600 eddy on my borred 383, now i start understand why i cant get it to run good, it´s to small!!! :walkaway:
Any idea of a carb to me??
Offline moper
« Reply #25 on: August 29, 2006 - 07:00:40 AM »
The reason the annulars are used on the larger carbs is the signal at lower speeds on the engines they are typically found on. The side effect can be surging if they are used on an engine that has the airflow for std boosters. That's why for years Dominators were known for poor street manners, until they were modified. I'll be interested to see how they respond for you. Also, where'd you get those valve covers? real nice...
Offline Dragula
« Reply #26 on: August 29, 2006 - 09:44:01 AM »
It will want a carb similar to what a 340 wants, just a touch bigger if its a stout 383. Typically, a box stock 750dp works very well on a 383. Although you can run an 850dp if its got a decent cam, headers, and a quick advance distributer. When you bring the timing in quicker, the motor can handle and wants more fuel. Drag cars have an unmistakable snap to the throttle, and its no secret how you get that in a street car. Just remember to port match all the carb gaskets and smooth the entry into the intake a little, and give the engine what it wants, timing and fuel.
Valve covers are the Summit Racing ones minus the logo. :clapping:
« Last Edit: August 29, 2006 - 09:45:35 AM by dragula »
    • Restorers
« Reply #27 on: August 29, 2006 - 01:18:13 PM »
Its a torker 383 intake(2500-6500 rpm), the cams i dont now anything about, but it seems to be pretty sharp, a msd 6al and headers, so i can go for something betwen 750 and 850 dp ??
« Reply #28 on: August 29, 2006 - 03:30:28 PM »
Since the cam is unknown, I would play it safe with 750cfm. You will see a BIG improvement over the 600 CFM that you have on there now.
Offline 426 pentastar
« Reply #29 on: August 29, 2006 - 05:06:51 PM »
If you really want a carb for your motor i can hook you up with the people that build them for nascar,they are not cheap but if you give them all the specks of the car and motor they will build it and all you will have to do is set the idle.If not just go with the big E carb company
