Well we have a special deal here people.383
I have had offers but they never seem to fullfill there end of the agreement
I have a custom blower system I'm selling
This is a setup designed by (dli) thingy Landy Industries
Included is
custom intake by dli for 440 chrysler big block cost around 989.99
(this may seem high but factor in he fact you buy a after market alu intake which
cut out the center and put in new metal and have cnc'ed)
I was told a few weeks ago these intakes are not touched for less than $1000.00
then you have the blower its self which is a powercharger 250 aka 670 3,599.99
now due to the fact they never produced a chrysler big block setup there was some
difficulty putting togeather a functional system and all so resulted in higher cost
My uncle paid over 7200.00 for this setup the following prices are ruff extimates from
him
idler pully 363.00
crank spacer 1 around 3 inch 164.00
crank spacer 2 around 2 inch 106.00
crank pully 10 rib upgrade kit 649.00
belt 100.00
gear set 269.00
nose seal kit 20.00
main housing gaskets and seals 92.00
then there are the dual holley 750 0-3310 4160s 476. each 952.00
crank bolt extended 22.00
dual k&n air filters 54. each 108.00
b&m 93330 siper charger seal x2 68 each 136.00
b&m intake to blower gasket 78.00
holley renew kit for carb 780 cmf 37-754 20.00
S A Design book ( A DO IT YOURSELF GUIDE TO STREET SUPERCHARGING 10.00 20.00
HOLLEY SPRING KIT X2 20.00
HOLLEY METERING PLATES X2 SEALED 36.00
VALLI RACING PYROMETER WIRE KIT 50.00
VALLI RACING PYROMETER BUNG KIT 64.00
VALLI RACING 3" PYROMEER WITH MOUNTING NEW NEVER USED 234.00
THROTTLE SYSTEM ARMS ECT BALL BEARING SET UP 350.00
THE ONLY THING YOU NEED IS HE ENGINE A VALLY PAN & VACUME LINE
ROUNDING TO THE NEAREST 10.00 THE TOTAL IS 8430.00
SOME STUFF MAYBE ALIL OFF BUT EVERYHING SHOULD BE CLOSE
I ROUNDED ANYTHING 4 AND UNDER DOWN 5 + UP
THIS UNIT HAS FRESH REBUILD
WAS A POLLISHED INTAKE BUT IS SOMEWHAT WEATHERED
I AM FIRM AT 3300.00
WILL CONSIDER PARTIAL TRADES FOR RAMCHARGER OR TRAILDUSTER SOLID WITH REMOVEABLE TOP
I WILL NOT ACCEPT ANY ROTTED OUT TRUCKS AND YOU WILL HAVE TO DELIVER IN TIMELY MANNER
I HAVE 2 PEOPLE WHO HAVE MADE OFFERS I WAS OK WITH BUT CURRENTLY CANT CONTACT EITHER ONE
I KNOW FOR SURE 1 IS STILL INTERESTED BUT IS IN ARMY AND CANT FIND TIME TO MAKE IT HERE
THE OTHER WAS PLANNING ON SHOWING UP ON THE 10TH
GEAR SET PROVIDES AROUND 5PSI TO 23PSI WITH TWEAKING POSSIBLE TO GO HIGHER MIGHT EVEN BE
ABLE TO GET 3PSI WITH DIFFERENT PULLY
AS I SAID BEFOR THIS IS A DLI SETUP AND IS ALL PROFESSIONALY DESIGNED I HAVE LOTS OF PICTURES
BUYERS WITH CASH PAYMENT WILL ALSO PAY SHIPPING APROX 70LB JUST FOR UNIT PLUS A BIG BOS OF
PARTS ECT
ALSO DONT COMPLAIN TO ME ABOUT PRICE I KNOW WHAT IT'S WORTH AND WHAT IT COST AND SEEN WHAT
IT CAN DO!!!
MY EMAIL ADRESS IS
DODGE89@COMCAST.NETMY YAHOO ID IS COOCOUGAR89SL
MY AIM & AOL NAME IS ALSO COOCOUGAR89SL I DONT USE AIM OR AOL MUCH
MY PHONE NUMBER IS 12317736706 ASK FOR DEREK
IF YOU WANT TO DO A TRADE I WILL NEED SPEFIC INFO ON TRADE AND LOTS OF PICTURES
I JUST WENT ON JEGS AND SUMMIT AND THESE PRICES ARE CLOSE TO CURRENT PRICES FOR CHEVY SMALL BLOCK PARTS
THIS IS THE POWERCHARGER 250 AKA 670 THERE IS ONE BIGGER AND LIKE 2 SMALLER
bag o return springs ect
