Author Topic: High pitched whistle from brakes  (Read 1673 times)
Offline 74MOPAR
« on: June 12, 2003 - 01:28:27 AM »
 At certain speeds or rpms, but mostly with no obvious connection to a certain speed or rpm  ??? I am getting an evil high pitched whistle that sounds as if it's coming from under the dash.  >:(  When I press in on the brake pedal it goes away for a moment sometimes, sometimes goes away for several minutes. Also sometimes varying the load on the engine gets rid of it.
  I am thinking there is a leak in the hose/fittings to the power brake booster that is exposed at only certain vacuum levels ?? Or the depth of the master cylinder piston- booster diaphragm uncovers a leak?
  Only depressing the brake pedal immediatley gets rid of it for the short term.
  Any experience with this ?
I'm thinking the sound is coming in thru missing grommets in the firewall.
« Last Edit: June 12, 2003 - 01:30:05 AM by 74MOPAR »
74 'Cuda + 73 Charger Rally + $$ + assembly= Noble M400
 03 Ram Hemi 4x4
 78 Aspen Super Coupe
Re:High pitched whistle from brakes
« Reply #1 on: June 12, 2003 - 06:05:27 AM »
Could be internal leak in the booster too
Offline Robb_Scottsdale
  • self inflicted victim of the ''might-as-well's''
« Reply #2 on: June 12, 2003 - 12:11:28 PM »
Vacuum hose to heater box controls ?   maybe ?
'68 Sport Satellite Convertible (383/4) (B5 blue) Survivor
'70 Challenger SE (383/2) (EK2 orange ) Survivor with light Perf Mods
'98 Ram 1500 Sport Club-Cab 4x4 (360) (all-black) 3in lift, 33x12.
