Author Topic: I have a prolem, help wanted!!  (Read 503 times)
Offline Gurragas of Sweden
    • Restorers
« on: August 10, 2006 - 03:32:57 AM »
It seem my car droop the fuelpresure after a while, if i start up and look at the fuelfilter its is filled whit fuel, but after 7-10 minutes the fuel disapear and it starting to pump air, i have try whit the mekanic pump and a electric pump whit same result, i am gooing nuts on this one :hyper:
can it drawing air somewhere from the gastank to the pump??
Re: I have a prolem, help wanted!!
« Reply #1 on: August 10, 2006 - 06:12:35 AM »
I had that problem once. Some not so smart person spliced my solid fuel line together with a rubber hose. The hose dry-rotted and cracked, letting air in the line. If I were you, I would inspect your solid fuel line to see if it is pinched anywhere. Also, there is a rubber hose in the back that connects the line to the gas tank. Maybe that is cracked?
Offline 4Cruizn
  • HEMI FISH
« Reply #2 on: August 10, 2006 - 08:24:31 AM »
Make sure your fuel line isn't too close to anything that could get hot and cause a vapor lock.  If this is happening a few minutes after startup, that is about the time things will start warming up!   :pullinghair:
    • Restorers
« Reply #3 on: August 10, 2006 - 02:25:41 PM »
I just came home from the garage, i think the problem are betwen the gastank and the pump, tomorrow i gona draw a new fuelline and see if it be better,
i realy hopes thats gona work, i want to drive a little before the winter.
