Author Topic: Rear Brakes  (Read 1809 times)
Offline 73EStroker
Rear Brakes
« on: August 10, 2006 - 10:11:57 PM »
 :canada:
I have head that for rear disc setups one can use a rear brake setup from a late 90s early 2000s Ford Explorer. Can anyone verify this? and if you can please advise if the parts are a straight swap or is there some custom work involved?
Barry (Salmon Arm)
Offline EvilTwinATX
Re: Rear Brakes
« Reply #1 on: August 10, 2006 - 10:48:46 PM »
that would be VERY cool.... never heard of it though.
Offline ntstlgl1970
  • T a c o c a t
Re: Rear Brakes
« Reply #2 on: August 10, 2006 - 11:33:42 PM »
the only thing common in size is the wheel lug pattern 5x4.5 , everything else would be custom
Re: Rear Brakes
« Reply #3 on: August 10, 2006 - 11:55:42 PM »
I have heard the rumor also , never tried it yet though
Offline larry4406
Re: Rear Brakes
« Reply #4 on: August 11, 2006 - 03:16:52 AM »
Dr. Dif on moparts.com has a kit that does this.  I think you have to change the axle ends where the backing plates would go.
Re: Rear Brakes
« Reply #5 on: August 12, 2006 - 12:50:55 AM »
you will definatly have to remove the axles & the drum brake backing plates & mount some kind of caliper adapter in its place
Offline chrisII
Re: Rear Brakes
« Reply #6 on: August 13, 2006 - 08:53:53 PM »
i think ive heard of this useing the entire rear. is that what your talking about. I know there was a 9" with disk breaks that is about the right width for E and B bodys
Re: Rear Brakes
« Reply #7 on: August 13, 2006 - 09:21:16 PM »
I don't know what it will take but I saw a TV auto show & some late model Ford truck with rear disk brakes also had a small drum just for the emergency brake.
Offline 73EStroker
Re: Rear Brakes
« Reply #8 on: August 14, 2006 - 09:20:16 PM »
ChrisII - to answer your question. I was informed by my painter/body guy that the Explorer would work for the rear discs setup. It would be to fit on a standard Chrysler 8-3/4 rear end. I am currently chasing two pre 70 Ford Dana 60s for my challener. Hopefully one is "posi" suregrip as that will be the old tough powerlock unit. But I will also look into this Explorer brake thing as I am going to install the ends off a Chrysler diff housing and run the standard axles and bearings. Just by fate I have kept some old truck axles with the bearing retainers around so I can do this. I will post the results to this site but won't be able to confirm for a month or so. Sigh - another winter passes before I can get her on the road.
Barry (Salmon Arm)
Offline Todd Smith
Re: Rear Brakes
« Reply #9 on: August 17, 2006 - 10:09:14 AM »
YA YA Keep us updated  :droolingbounce:
Plumbcrazy
I don't suffer from insanity.
I enjoy every minute of it!
Offline pettybluecuda
  • www.cudaregistry.com
    • 70-74 barracuda-cuda' registry
Re: Rear Brakes
« Reply #10 on: August 17, 2006 - 10:44:41 AM »
 I just picked up a posi rear end with factory disc brakes this week, Im thinking it was out of a new yorker or something like it. Does anyone know whats it worth or is anyone looking for one?
later,
Jesse
Re: Rear Brakes
« Reply #11 on: September 12, 2006 - 07:05:59 AM »
Have an idea for you guys, Working on my 98 Caravan I discovered the bolt pattern is the same as my '73 chally, 4.5" . My van does not have rear disks but I know that they were available. Wonder if those hats would fit. If so an adapter could be made for the caliper and there ya go.
Also same bolt pattern for my 98 GT.   :bigshades:
Offline Hopalong
  • HEAD OFF! Apply directly to the neck line!
Re: Rear Brakes
« Reply #12 on: September 23, 2006 - 08:55:26 PM »
Here's an option for you.  http://www.speedwaymotors.com/xq/aspx/paging.yes/dept_id.351/display_id.1999/qx/Product.htm  Speedway is the nation's oldest speed shop in the nation and has a lot of neat stuff.  I have been eyeballin' this kit for some time because it looks so easy.  Uses Wilwood style rotors and hats and gm calipers with parking brake.  Just an idea.
{oo/===\oo}
Offline EvilTwinATX
Re: Rear Brakes
« Reply #13 on: September 24, 2006 - 12:23:53 PM »
Do it!!  :popcorn:
It does seem  simple.... maybe TOO simple.. :roflsmiley:
Offline Hopalong
Re: Rear Brakes
« Reply #14 on: September 25, 2006 - 04:18:25 PM »
I wish I was ready for brakes!  Still working on the body and all first.
{oo/===\oo}
