Finally got some pics not so newbie from P.R
Author Topic: Finally got some pics not so newbie from P.R  (Read 2447 times)
Offline AAR71
« on: August 10, 2006 - 11:10:22 PM »
 :working: Well finally got some pictures of my 71 barracuda to post, this is when i brought her home just before the
tear down. Right now i'm doing the bodywork on her will try to post those pics later.
« Last Edit: August 10, 2006 - 11:27:04 PM by angelo ortega »
Offline 360 'CUDA
Re: Finally got some pics not so newbie from P.R
« Reply #1 on: August 10, 2006 - 11:54:07 PM »
So the tropics and salty air wasn't good to her huh?
'71s are the hot ticket now a days but that one is gonna need some work
 :2thumbs:
Offline ESGEE
  • 1970 Challenger RT/SE
    • SG´s site
« Reply #2 on: August 11, 2006 - 04:50:22 AM »
Looks like you have some metalwork to do, is the rest of the car ok or is it same all over?  :cheers:
70 Challenger RT/SE(Looking for 383 Magnum N0B196875)
70 Challenger RT/SE(Looking for 383 Magnum N0B115166)
70 Challenger SE(RT/SE clone)
69 Charger RT/SE 4speed Trackpac
70 Charger 500
Offline AAR71
« Reply #3 on: August 11, 2006 - 05:44:11 AM »
 :working: I used to live in NEW JERSEY and the rust over there was pretty bad on classic cars but being surrounded by the ocean is even worst or at least my car has never been taken care of. :22yikes: As far as how much work she needs it's preety bad but nothing a good MIG welder and some replacement sheetmetal can't handle; my phylosophy if it is not crushed into a giant metal block it can be fixed!!!
Offline ESGEE
    • SG´s site
« Reply #4 on: August 11, 2006 - 07:08:46 AM »
Sounds like you have everything under control :bigsmile:
70 Charger 500
Offline Judgester
  • Mid-Life Crisis Relief
« Reply #5 on: August 11, 2006 - 02:01:36 PM »
I like your philosophy  :2thumbs:
Offline Kapteenikosmos
« Reply #6 on: August 11, 2006 - 02:32:15 PM »
That door hinge frame is bit tricky to repair because there is separate frame (which is only spot welded into those upper layers of sheet metal) for the hinge behind three layers of sheet metal and all those layers are propably busted in your car too. My challenger looked about the same. If you are going to repair that try to get that actual door hinge frame welded into the backside metal so it stays put when you rip the busted layers of sheet metal from front of it. The actual frame is from much thicker metal and I would guess that it should be in decent condition. The salty air does very bad things to the pillars, hopefully yours are in decent condition. Mine had totally busted c pillars and a pillars were thin from some points but mainly ok.
Have fun with the body work  :2thumbs: and keep us posted for pics!
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
Offline 70nos340 barracuda
« Reply #7 on: August 11, 2006 - 04:27:43 PM »
Offline 422STROKER
  • Member Since 6/3/06
« Reply #8 on: August 12, 2006 - 08:51:34 PM »
Looks  like fun to me!   :useless:
Tom
Tom
Offline AAR71
« Reply #9 on: August 13, 2006 - 10:43:27 PM »
 :working:
                Here are some more update pictures; not for the faint of heart, viewer discretion advised!!!
Offline 71340RT
« Reply #10 on: August 13, 2006 - 10:50:22 PM »
Looks like you are very motivated and have everything under control. Keep us posted with pictures of your progress and good luck.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline 360 'CUDA
« Reply #11 on: August 13, 2006 - 11:44:28 PM »
So ya need a new cowl huh?
Offline AAR71
« Reply #12 on: August 14, 2006 - 09:14:06 PM »
 :working:
 Ya she did need a new cowl and firewall. At the begining of the teardown I freaked out but after I sat down and figured out where to start it all starts to fall in place; it's always that first cut that is nerve racking. Well enough of the gab;  here are more updates... enjoy!!!
Offline AAR71
« Reply #13 on: August 15, 2006 - 09:47:43 PM »
 :working:
             Some more pics.
Offline falcon50flier
« Reply #14 on: August 22, 2006 - 10:03:44 AM »
good progress on the tin Angelo. welcome to c-c.com
70 Challenger convertible
518 cid Hemi, TF727, 3.73 Dana 60
