Work completed. Ending 08/13/06.
Author Topic: Work completed. Ending 08/13/06.  (Read 3714 times)
« on: August 13, 2006 - 05:36:29 AM »
OK,
  This week, I'll go first. It's a minor thing, but it took me some nerve to drill more holes into the body of my car.  :scared:  :scared:  :scared: You only get one chance to do it right. I added hood pins.  :woo:  :woohoo:
Offline Katfish
  • 70 Challenger
Re: Work completed. Ending 08/13/06.
« Reply #1 on: August 13, 2006 - 05:40:53 AM »
Nice, always loved the look hood pins add!
Did you remove the center latch?
Offline 422STROKER
  • Member Since 6/3/06
« Reply #2 on: August 13, 2006 - 07:42:24 AM »
What did you use for a reference?  I'm going to try this today, I got my hood pins on thurs.  Any pics of the underside locations?  Sorry for the questions just want to be sure!
Thanks Tom :droolingbounce:
Tom
Offline ESGEE
  • 1970 Challenger RT/SE
    • SG´s site
« Reply #3 on: August 13, 2006 - 08:21:19 AM »
Hood pins allways look good with a sixpackhood :bigsmile: Your car is sure great looking :cheers:
70 Challenger RT/SE(Looking for 383 Magnum N0B196875)
70 Challenger RT/SE(Looking for 383 Magnum N0B115166)
70 Challenger SE(RT/SE clone)
69 Charger RT/SE 4speed Trackpac
70 Charger 500
« Reply #4 on: August 13, 2006 - 09:18:36 AM »
No, the center latch is still there. The pins were put on more for show, but's it's good to know they serve a function "just in case".  :grinyes:
« Reply #5 on: August 13, 2006 - 09:21:33 AM »
Believe it or not, my inner fenders already had holes for the pins to mount to. So that was a good start. The hood has little circles on the outer edge, let's call them cut-outs. I pretty much drilled thru the center of those cut-outs. I hope the 72 hood works the same way for your sake. I'll go get some pics later for ya.
Offline 422STROKER
« Reply #6 on: August 13, 2006 - 09:27:09 AM »
I have a T/A style hood so it doesn't have those little circles underneath!  This stinks - like you said only one shot.  I'm in the garage now and getting gunshy! Do you have an approx measurement from front/edges to center that would be a start for me.  Do the pins mount through the rad support?  Seems to far back to me.  I have fiber fenders also and worried they aren't strong enough to hold hood pins and hood at speed!  Any input here is appreciated.
Tom
Tom
« Reply #7 on: August 13, 2006 - 09:59:27 AM »
Tom,
  Here are my pics. They measure the same each side. The good news is you can make the holes a little bigger than necessary, because the stainless lid will cover it.  :naughty: I worked on the 2 big holes first. After I was satisfied how the hood opened, and closed, I put on the 4 little screws to hold each stainless cover in place. As I mentioned, I already had the holes in my inner fender for the posts. You have to play a little to get the posts the right height.
« Reply #8 on: August 13, 2006 - 10:00:26 AM »
more...
Oldschool
« Reply #9 on: August 13, 2006 - 10:15:13 AM »
Looks good Mike!  :2thumbs:
As for me and the Beast, I have a small setback in my plans for some track time.   :walkaway:  When you run 10:99 or faster, you must have a current NHRA chassis certification.  The certification expired in April this year.  Well, there is only 1 guy that can do a Chassis Cert in Ga and he is 3 hours away.  I loaded up the Beast and off I went.  His inspection discovered that since the last certification 3 years ago, the rollcage rules have changed.  Long story short, I need another section of cage installed before I can do my thing on the track.   :swear:  No big deal, but it does delay my fun.  I have a friend of mine that will take care of it, but he is backed up at his shop somewhat.  I'll get it done as soon as I can and report back.  Oh---btw---he did say everything else was way above par on the car and he tried to get me to contact some of his S/S racing buddies and sell em the Beast!   :scared:
Offline 422STROKER
« Reply #10 on: August 13, 2006 - 02:35:18 PM »
Tom,
Thanks Mike
I spent the afternoon w/your pis and it's done!  I had the holes in the fenders as well and used these as a reference to start.  I also looked at as many pics as I could find of fiberglass hoods.  I only drilled holes and mocked it all up as my car is supposed to get painted this week.  I also spent some time test fitting trunk/quarter extensions, hood mouldings.  Stripped headlight and tailights removed the rest of the gaskets that needed to come off.  Again thanks for your help w/hood pins.  Is that a steel hood?  Looks like they did a nice job molding the scoop to it. :2thumbs:
Tom
Tom
« Reply #11 on: August 13, 2006 - 03:51:52 PM »
Thanks Mike
Tom
Tom,
   I am SOOO glad I could help you!!!  :grinyes: I'm glad you got 'er done!!  :clapping: As for my hood... UMM, yep, that's a fiberglass hoodscoop on a steel hood. Nice idea, but that was my introduction into body work. Trying to mold it right.  :pullinghair: What you see ISN'T what I saw when I bought the car.  :lol: My life isn't easy!!!  :grinno:
Offline 422STROKER
« Reply #12 on: August 13, 2006 - 04:02:09 PM »
Well it looks like you did a nice job to me!  Thanks again for the help the tape measure shots were nice.   :2thumbs:
Tom
Tom
« Reply #13 on: August 13, 2006 - 04:15:23 PM »
Tom,
  again, I am only SOOO happy when I can help someone!!  :thumbsup: Thanks!!!  :worshippy
Offline 422STROKER
« Reply #14 on: August 13, 2006 - 04:21:01 PM »
I forgot that I also test fit my new bumpers from YO made by Keystone  seem nice to me  Sorry no pics until after paint. :2thumbs:
Tom
P.S. Mike I don't know why the other members give you such a hard time? :bigsmile:
Tom
