Author Topic: 340 suggestions  (Read 3253 times)
Offline JimCuda
  • MOPAR > Move Over Plymouth Approaching Rapidly
Re: 340 suggestions
« Reply #15 on: August 24, 2006 - 06:33:41 PM »
if you are going to boost it Use a Forged piston or get a few spare blocks
I agree, just seeing if anyone is running boost and if they are what type of pistons are they running. Anyone?
Re: 340 suggestions
« Reply #16 on: August 25, 2006 - 01:34:17 AM »
I have built some engines with boost , any good forged piston , Speed Pro , Diamond etc will work
Offline moper
Re: 340 suggestions
« Reply #17 on: August 25, 2006 - 06:48:20 AM »
Definately NO BOOST with hypers. You might as well just skip the assembling part and go right to "rebuild with forged", because the process of setting up a boosted engine will destroy them. They can take the pressure, they cant take ANY, and I mean ANY detonation. Evrything has it's performance window...that's the end of hyper pitsons'. I have sen too many mopar blocks broken from that, but they use long rods, so the ends just slam around in the bores when the piston reverts back to powder... 4.6 Fords are just tossed away...
