Author Topic: key stuck...shifter? help  (Read 2835 times)
bbscamp
« on: August 15, 2006 - 07:45:18 PM »
I pulled out the console and slapstick shift along with the motor and trans.  I had left the key in the ignition....in the on position.  Now I can't turn it back to "off" to get the key out.   Any clues how I can?  I saw no linkage between the shifter and column.....is there something on the brake pedal?
Offline Challenger6pak
Re: key stuck...shifter? help
« Reply #1 on: August 15, 2006 - 07:55:49 PM »
What year is the car?  Does it have the lever you push down on the column to release it?
Alaskan_TA
« Reply #2 on: August 15, 2006 - 08:24:16 PM »
Sounds like a '70 model. There is an arm on the bottom of the column that attaches to your shift linkage. If you move that arm (up, I think?) you should be able to remove the key.
Barry
bbscamp
« Reply #3 on: August 15, 2006 - 08:41:44 PM »
yes a 70.  I don't recall disconnecting any lever.  is it in the eng. compartment?????    any picts?   mines a console shift.
thnkx
Alaskan_TA
« Reply #4 on: August 15, 2006 - 09:47:53 PM »
The rod could be missing, if so you may have bumped the lever while taking the engine out?
The arm is on the column, in the engine bay, let me look for an image.........
Offline ShelbyDogg
« Reply #5 on: August 15, 2006 - 09:53:55 PM »
If You rotate the bottom of the column, right in front of the dash clockwise till it stops, you can turn the key to the off position.
Alaskan_TA
« Reply #6 on: August 15, 2006 - 09:57:28 PM »
This should help, the arm is circled in red;
« Reply #7 on: August 15, 2006 - 10:52:40 PM »
I agree with above , just rotate the bootom collar on the column & the key will turn back & come out
Offline Cuda Cody
  • Vancouver, WA
« Reply #8 on: August 15, 2006 - 11:04:43 PM »
All good advice!  That should be it.
bbscamp
« Reply #9 on: August 16, 2006 - 06:07:34 AM »
 :bigsmile:  Thanks guys.   Alaskan_TA:  what manual is the image out of?
Offline heminut
« Reply #10 on: August 16, 2006 - 08:54:54 AM »
:iagree: The first time that happened to me I stood around awhile scratching my head and going WTF? ???
1970 5.7 Hemi Cuda
Alaskan_TA
« Reply #11 on: August 16, 2006 - 10:56:36 PM »
It is from the factory service manual, Year One sells reprints I believe? It is something that EVERY car owner should have, they are invaluble.
Barry
bbscamp
« Reply #12 on: August 20, 2006 - 06:48:50 PM »
yupper....rotated the bottom collar and out it came.  Thanks for the help!   :bigsmile:
« Reply #13 on: August 22, 2006 - 12:18:15 AM »
 :2thumbs:
Offline willhaven
« Reply #14 on: February 04, 2013 - 06:13:52 PM »
For the record, this just saved me a lot of aggravation. My key has been stuck in the column for months. I was about ready to attack it with WD-40 and make a real mess. I thought my old worn out original key hadn't been duplicated properly and the new key just got stuck.
I guess the collar just turned around while I was driving and trapped my key temporarily*.
I guess it also means I have a 70 column in my 71. No biggie, just good to know these things.
*three months
