Best crate motor?
Author Topic: Best crate motor?  (Read 7960 times)
Offline Blackcuda
Best crate motor?
« on: August 16, 2006 - 07:57:33 AM »
Other than a Hemi, what is the best crate motor that gives you the best bang for the buck?
Offline heminut
Re: Best crate motor?
« Reply #1 on: August 16, 2006 - 08:39:34 AM »
My guess would be the 380 horse 360.
1970 5.7 Hemi Cuda
« Reply #2 on: August 16, 2006 - 09:03:05 AM »
the 395 hp 360 crate delivers a dyno tested 217 at the rear wheels through a 727 trans where si the Yawn smiley
 get one built
Offline moper
« Reply #3 on: August 17, 2006 - 06:29:54 AM »
The Ford Motorsport 380 horse 347... :bigsmile:
I wouldnt buy a Mopar crate. If I was forced at gunpoint,the 360 versions have the best "no issues" ratio. The Hemis are the worst. But for the same money, a good shop can build a better engine.
Offline Blackcuda
« Reply #4 on: August 17, 2006 - 07:08:17 AM »
What is the problem with the Hemi's? :clueless:
« Reply #5 on: August 18, 2006 - 12:26:55 AM »
A friend was relating his experince with the Hemi , warmed up to 180* picked up a miss , pulled the valve cover & a valve was stuck open pulled the head & 2 valve seats dropped out of the heads , contacted Mopar for warranty told GFY
 when they went to repair the head they heated it to 200* & the rest of the seats dropped out
« Last Edit: August 19, 2006 - 01:28:13 AM by Chryco Psycho »
Offline moper
« Reply #6 on: August 18, 2006 - 05:54:49 AM »
well, the ones I've head about first hand (I know/knew the owners)... Noises traced to: rod bolts not torqued, rods in backwards, main cap missing main bolt (how the heck???). These next ones were problems found after some run time..minutes, or a few miles: lifter noises, smoking due to rings with gaps lined up, guides too lose (same motor, had 2 valves too tight...must average out), leaking intake gaskets. In one case, he got one, it was bad out of the crate (you could hear a rod banging around when turning it with the starter), the bolts were never tightened, and the bearing was ratting around in the end of the rod. So, MP warranteed it. The second one ran for 3 mintues before the oil pressure went away, and it was shut down and returned without investigation. #3 was gotten, installed, and leaked out the rear main,and ended up having a ton of endplay. That one was sent to a hemi specialist, rebuilt by him, and has been running well for 3 years. Considering I only know about 6 guys that bought them over the course of 7 years. Of those 6, 4 had problems of some sort, requiring parts and labor to repair. they have a 33% GOOD record by my first hand experience. And I read about a lot of others. Not making the power they should, poor running, smoking, major leaking. Of the ones I'm personally saw, MP replaced the early one, and supplied parts only (no monetary reimbursment) for shops or owners to fix the others. For $10K or more, as an assembly, they flat out suck. They are a great way to get your hands on a new block and parts tho. I would still buy one. But the whole thing would come apart before it was ever installed and I'd go thru every inch of it.
Offline matt63
« Reply #7 on: August 18, 2006 - 10:00:04 PM »
I've heard of rear seals being installed backwards from the mfg but this was some time ago.  If you look at the cost of buying a crate motor, disassembling and checking it out and reassembling it with new gaskets, etc, I wonder if having one built locally is any more expensive.  The advantage of getting one built is that you can chose which cam, intake, etc you want.
Matt in Edmonton
'68 Valiant
Offline 67Vette427
  • My other car is not a Rambler
« Reply #8 on: August 21, 2006 - 12:16:04 AM »
There is a big back order now on the Hemi's because of the problems. Who knows when they'll get them out again.
1 of 1 Mr Norm's T/A/ 2015 Hellcat, sublime/ 13 Power Wagon
Offline ESGEE
  • 1970 Challenger RT/SE
    • SG´s site
« Reply #9 on: August 21, 2006 - 09:43:16 AM »
I heard that the 360 is a good one. Anyone know anyting about the 5.7L Crate?
70 Challenger RT/SE(Looking for 383 Magnum N0B196875)
70 Challenger RT/SE(Looking for 383 Magnum N0B115166)
70 Challenger SE(RT/SE clone)
69 Charger RT/SE 4speed Trackpac
70 Charger 500
« Reply #10 on: August 22, 2006 - 12:36:24 AM »
the 360 we got is Junk , I am fighting with Mopar to get it returned & credited for the $$ spent
Offline asm74
« Reply #11 on: August 22, 2006 - 02:12:18 AM »
Aw no.... what's wrong with it?  I've heard a few people rave about the 360 crates... do you think you just got a bad apple?
73 Challenger
« Reply #12 on: August 22, 2006 - 02:33:44 AM »
 :scared: can`t all be bad , But I would certainly  take it apart & check it
Offline Blackcuda
« Reply #13 on: August 22, 2006 - 07:27:48 AM »
If I were to order a 426 crate motor out of Jeg's for $12,999, what are the chances I'll get a Lemon? :eek4:
Offline ESGEE
    • SG´s site
« Reply #14 on: August 22, 2006 - 08:00:58 AM »
But isent there a company who take it apart and run it in before letting it go, sure its more expensive i can imagne, but when buying a new 426 for 13k+ its a good idea :bigsmile: Dont know that companys name... :clueless:
70 Charger 500
