Firewall grommet used for what tube or hose?
Author Topic: Firewall grommet used for what tube or hose?  (Read 1336 times)
RedLine
« on: August 16, 2006 - 09:45:03 PM »
If you look at the picture I attached and look below on the fire wall where the two drain tubes go thru from the heater box,  you will see another hole that has three small screw holes around it --  can someone help reminding me what is this was used for?  I couldnt find it it the service manual. and an friend with an SE is asking. here's the firewall hole
« Last Edit: August 16, 2006 - 09:47:42 PM by RedLine »
Re: Firewall grommet used for what tube or hose?
« Reply #1 on: August 19, 2006 - 08:29:14 AM »
Chris,
  On my car, there is a small nipple coming out of that hole. Whatever it is, is mounted from the inside. I'll have to snap a pic later for you. I figure it must be AC related, because mine connects to nothing, and my AC stuff was removed.
Offline 1BADFISH™
« Reply #2 on: August 19, 2006 - 08:35:06 AM »
Chris,
 :iagree:  I have the same little hole and my car is an A/C car with stuff removed.
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
« Reply #3 on: August 19, 2006 - 12:02:48 PM »
drain for the a/c condensation so it doesn't make the winsheild fog up
Offline 1BADFISH™
« Reply #4 on: August 19, 2006 - 12:29:44 PM »
Does anyone have one of these they'd like to sell?? I would like to plug the hole.
Charlottetown, PE
« Reply #5 on: August 19, 2006 - 02:46:34 PM »
Here's what mine looks like.
RedLine
« Reply #6 on: August 19, 2006 - 03:34:25 PM »
Thanks Mike-  Exacty-  I have that grommet piece.... but I dont know if it is the vaccuum line fromt he carb to the ac/heater box-  or some other drain line or what.
Offline 426 pentastar
« Reply #7 on: September 03, 2006 - 06:26:52 AM »
I beleive its for the vacume line from the a/c acuater to intake
