You could have put in the cam or dist drive retarded when you did the cam. Did you degree it? Do you know what the real timing curve is on it? That means how much initial timing (set by turning the dist.), plus the centrifical (mechanical advance under the cap) plus the vaccum advance (the vaccum can). If you have a basic timing light, and a timing tape ($#), you can figure all this stuff out easy. Also, what is the cylinder pressure readings with the new cam? (a compression test, with all the plugs removed from the engine, and the throttle blocked wide open...)
