Author Topic: fuel sender and turn signal switch  (Read 1786 times)
sleepychallenger
« on: August 17, 2006 - 01:09:37 PM »
im looking for a 70 challenger fuel sending unit  and a turn signal switch. let me know if you have one and how much please
Re: fuel sender and turn signal switch
« Reply #1 on: August 17, 2006 - 02:18:40 PM »
If you want new, the sending units can be had on E-Bay in the $60-$80 range. Unfortunately, the turn signal switch for a 70 E-Body is unique. It costs $55 at Year One. I hope someone has some cheaper used stuff for you.  :thumbsup:
sleepychallenger
« Reply #2 on: August 18, 2006 - 12:55:04 PM »
me to. I dont like going totally cheap but I am only a 2 stripe Airman and money doesnt just flow to us. I appreciate all the help that I can get and all of the advice that everyone has been giving on my other posts.
V/R  (very respectfully)
Drew
Offline ShelbyDogg
« Reply #3 on: August 18, 2006 - 01:30:09 PM »
The HELP section of Autozone sells the top portion of the turn signal switch that contains the part that always breaks. Any auto parts store can get you that "HELP" stuff. As for the sending unit, get a NEW one. The gas guage sending unit has a little button that wears off after constant friction  against the resistance wire. The connection rivet also starts going flaky after years of use too.  Fix it right once and you wont spend twice.
sleepychallenger
« Reply #4 on: August 18, 2006 - 01:33:07 PM »
anyone wanna keep a watch on ebay for me and let me know. I dont have a computer at home but do have freinds that can bid for me. just cant count on them to keep an eye out for me.
Will that turn signals part fix my turns not working at all.
Offline ShelbyDogg
« Reply #5 on: August 18, 2006 - 02:07:03 PM »
I bought one on EBAY today for 54.95.  3/8" with a return line is the way to go.     I use them for fuel injection and drill out the 1/4" return line and install a 5/16 line instead.   The 5/16 sending unit was 2 dollars cheaper.
The turn signal part wont fix your turn signals if it isn't the switch.  Usually bad turn signals, if it's the switch, often leads back to the emergency flasher portion of the turn signal switch.
sleepychallenger
« Reply #6 on: August 19, 2006 - 04:01:30 PM »
emergency flashers work. left front turn light is dimmer than the others!?!
Offline ShelbyDogg
« Reply #7 on: August 19, 2006 - 09:20:13 PM »
First Change the bulb, second, clamp a battery jumpercable to it and ground the other end to see if that makes it work.  It's usually a bad ground.
sleepychallenger
« Reply #8 on: August 21, 2006 - 06:40:56 AM »
I will give that a shot this weekend. that wouldnt make the whole turns system not work would it?
Offline ShelbyDogg
« Reply #9 on: August 21, 2006 - 07:32:08 AM »
I thought you said the left front was just dimmer than the others. Does everything not blink? Did you change your flasher?
sleepychallenger
« Reply #10 on: August 21, 2006 - 08:58:32 AM »
the emergency flashers work but the turns do not. when the lights are on the left front is dimmer than the rest.
Offline ShelbyDogg
« Reply #11 on: August 21, 2006 - 09:08:37 AM »
When you turn the right turn signals on, do the right tail lights and front turn signal come on, not blinking?
sleepychallenger
« Reply #12 on: August 21, 2006 - 09:36:24 AM »
no. nothing happens when I turn the sinal on. only time that they flash is when I turn on the hazzard flasher, even then the fronts turn off when I do that but the rears flash.
sleepychallenger
« Reply #13 on: August 21, 2006 - 09:37:57 AM »
NOTE: there was 18.6 volts pushed through my whole system for like a week and a 1/2.
NOTE: If you buy an one pully alternator from O'rileys, it is not right. the part number they have is wrong and all of the issues that I am having will happen to you!!!!
Offline ShelbyDogg
« Reply #14 on: August 21, 2006 - 09:56:18 AM »
That alternator can only push 18.6 volts if the voltage regulator tells it to. Was the voltage problem fixed after you changed the alternator back? It sounds like the voltage regulator is bad.
As for the blinkers, change the flasher.
