Author Topic: 340 block based 418  (Read 14394 times)
Offline matt63
Re: 340 block based 418
« Reply #15 on: July 19, 2007 - 10:25:24 AM »
How 'bout this 408 on pump gas. . . . Turbo  :bigsmile: :faint:
I hope he's running an R3 block.
Matt in Edmonton
'68 Valiant
Offline mopower
« Reply #16 on: July 28, 2007 - 07:51:58 AM »
i had my 340 dyno at 500 horse , not stroked. punched 60 over so actually its a 348 . i also have $10,000 in this motor, cheater system next week.600 ponies...eating chevys and ****n fords
Offline jvike
  • Pro-Touring Cuda
« Reply #17 on: July 31, 2007 - 12:19:02 AM »
Mopower, any more info on that motor?
Offline mopower
« Reply #18 on: July 31, 2007 - 10:20:05 PM »
70 block forged crank eagle h rods forged pistons,edelbrock rpm heads port & polished.crane pro rollers 1.6 ratio msd digital 6 tti ceramic headers holley 700 double pumper 4 corner idle rejeted..cam is xtreme energy hyd 579 lift 10.7:1 comp dynoed at 490hp 515tq dyno sheet to follow
Offline mopower
« Reply #19 on: July 31, 2007 - 10:23:33 PM »
if i remember correctly its only 335 to the rear tires.... i 'll double check
Offline jvike
  • Pro-Touring Cuda
« Reply #20 on: August 04, 2007 - 04:14:04 AM »
 :wow: That's some great numbers for a 340. Do you remember what RPM it made power?
Offline mopower
« Reply #21 on: August 04, 2007 - 09:00:49 AM »
actually were having problems with the tci stall convertor its supposed to stall at 3200 but its stalling at 4800 so the new precission convertors on the way with anti balloning plates..i havent posted dyno sheet,cause were gonna have better results after the new one is installed wensday. iwill post asap
Offline mopower
« Reply #22 on: September 13, 2007 - 10:22:46 PM »
just put nos in my 340 ....615 ponies at the flywheel 425 to the ground :clapping:
Offline 440mike
« Reply #23 on: September 14, 2007 - 12:56:21 AM »
Is that a stock 340 block or aftermarket ?   :jumping:
Offline mopower
« Reply #24 on: September 14, 2007 - 02:06:29 PM »
70 block stock, probably blow it up, but hey then we can build a bigger one. going race block next
Offline Katfish
  • 70 Challenger
« Reply #25 on: September 14, 2007 - 02:14:08 PM »
That's 30% drivetrain losses, seems sorta high.  Always heard 15-20%, would think you should have 500 at the wheels?
Offline mopower
« Reply #26 on: September 14, 2007 - 08:50:59 PM »
brand new dyno says 415.. see i allways heard 30% loss go figure ????????
Offline jvike
  • Pro-Touring Cuda
« Reply #27 on: September 24, 2007 - 01:14:37 PM »
How did the racing go?  :burnout:
« Reply #28 on: September 24, 2007 - 01:30:23 PM »
Kinda depends on your convertor and trans, but that is close.
It isn't a stroker, but my stock block, stock stroke 360 is 427 at the crank, altitude corrected.
