Author Topic: Lugnut threads  (Read 1899 times)
Offline Bonkers
Lugnut threads
« on: August 17, 2006 - 03:35:30 PM »
Did late 60s mopar cars originally come with reverse threaded studs on the driver's side? I know it was used on older trucks, but I discovered my B-body had them after breaking two studs off last night.
I drive WAY too fast to be worried about cholesterol.
"First rule of performance modification - not being able to accelerate won't kill you nearly as fast as not being able to stop." - Dad-in-law and chief mechanic.
Offline Hot_Rodder
Re: Lugnut threads
« Reply #1 on: August 17, 2006 - 03:41:41 PM »
My '69 Charger R/T did... I always said, if I had to change anything on the front end, the first were gonna be those.... Well, now the guy who owns it now, has done a disc brake conversion on it, kit from SSBC if I remember right.
Oldschool
Re: Lugnut threads
« Reply #2 on: August 17, 2006 - 04:04:46 PM »
I owned 6 "B" bods back in the day.  They were year models '67 - '70.  All of them had left hand thread on the driver side.  I never changed em, I just turned em the right way..    :2thumbs:
Offline 422STROKER
  • Member Since 6/3/06
Re: Lugnut threads
« Reply #3 on: August 17, 2006 - 04:08:20 PM »
Yes, I found out the hard way changing a flat in the middle of winter-snapped all 5 off!  Man it was cold fixing that mess.  The guy at the counter said "Left or Right hand thread?"  In my head I said "OH SH*T" out loud "Right". :roflsmiley:
Tom
Tom
Re: Lugnut threads
« Reply #4 on: August 17, 2006 - 06:27:31 PM »
Yep, 70 and earlier had the left handed nuts. What a great idea..huh???  :banghead:
Alaskan_TA
Re: Lugnut threads
« Reply #5 on: August 17, 2006 - 06:49:48 PM »
TSB announcing the change.....
Offline Lunchbox
Re: Lugnut threads
« Reply #6 on: November 06, 2006 - 10:11:59 PM »
Wish I remembered this before I twisted one off, it mushroomed out the hole on the rim can that be fixed or am I going to be searching for a new old rim?
Re: Lugnut threads
« Reply #7 on: November 06, 2006 - 11:24:37 PM »
anything can be fixed , but price wise it may be cheaper to replace it depending what size & style rim it is
Offline Lunchbox
Re: Lugnut threads
« Reply #8 on: November 08, 2006 - 05:38:32 PM »
Its a 1970 15/7 ralley rim
Offline TreeFrog
    • TreeFrog
Re: Lugnut threads
« Reply #9 on: November 22, 2006 - 01:23:11 PM »
Could be wrong but I though Dad's Dodge truck have them (73) and could have sworn the Challenger(73) had them...now I will have to go look.
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline Madmax440
Re: Lugnut threads
« Reply #10 on: November 22, 2006 - 04:43:22 PM »
Must have been the same guy at Chrysler that decided that the keys should go in upside down.
Re: Lugnut threads
« Reply #11 on: November 22, 2006 - 05:02:44 PM »
 I can't comment on the trucks, but they stopped this hideous idea after 1970 in E-Bodies. I can't imagine how many people took their car to a shop for a tire change, and stumped the mechanic.  :smilielol:
Re: Lugnut threads
« Reply #12 on: November 23, 2006 - 01:09:14 AM »
You must own a GM , in reality Chysler keys go in the right way with the pins on top so dirt falls out of the lock Not into the mechanism , virtually all residential & commercial locks work the same way with the pins on top of the GM is the one that is backwards
Re: Lugnut threads
« Reply #13 on: November 23, 2006 - 01:11:05 AM »
 Dodge quit left hand threads in 70 BUt I worked on a Freightliner tandem Dump truck today , early 80s & Yup it had left hand threads on the left side
Offline Madmax440
Re: Lugnut threads
« Reply #14 on: November 26, 2006 - 09:04:56 AM »
That does make perfectly good sense now to have the key in the other direction. I had never thought about it that way. Yes, I have had GMs since about 1979 when I departed Mopar and bought a 1979 Z-28 (The only brand new car that I have ever bought and at the time wasn't crazy about any others that I had to choose from).
