Author Topic: Small Block 340 Piston Considerations  (Read 12489 times)
Offline JimCuda
  • MOPAR > Move Over Plymouth Approaching Rapidly
« on: August 19, 2006 - 10:09:46 AM »
Anyone have any vendor recommendations for replacement pistons for you small block 340? Standard sizes or over bored.
Re: Small Block 340 Piston Considerations
« Reply #1 on: August 19, 2006 - 11:31:31 PM »
Speed Pro still has the 68 stock replacement piston , forged & it is above deck with close to 10:1 compression
 other than that you can check with Diamond , Je , Ross , Possibly Probe & see what they ahve available , any are a good piston & do a lot of Mopar stuff
Offline JimCuda
« Reply #2 on: August 20, 2006 - 09:07:29 AM »
Any one of those guys make a 8.5:1 forged piston, standard 4.04 bore?
« Reply #3 on: August 22, 2006 - 12:51:17 AM »
the  Speed Pro L 2385F will make 8.2 with a 68 cc head
the L2316F is 9.7 with a 68 cc head
both are available in std bore
Offline JimCuda
« Reply #4 on: November 08, 2006 - 09:53:08 PM »
I'm no longer in the market for stock pistons but good after market pistons .030 over.
More than likely a budget stroker motor.
Offline moper
« Reply #5 on: November 09, 2006 - 10:51:47 AM »
Diamond with dish (for use with Edelbrocks or decent closed chamber heads...) 51411
Flat top (open chamber/racey with closed cahmber, very light...) 51008
Ross dished type   99786
Diamonds are a nicer peice IMO, and sometimes a little cheaper.
« Reply #6 on: November 09, 2006 - 03:23:28 PM »
I agree Diamond are nicer , lighter & better quality
Offline JimCuda
« Reply #7 on: November 09, 2006 - 06:35:12 PM »
Are these the ones on Campbell for 579.55 for the Dish and 551.95 for the flat top?
http://www.campbellenterprises.com/parts.php?type=search&query=dia51411
http://www.campbellenterprises.com/parts.php?type=search&query=dia51008
Any place cheaper?
« Reply #8 on: November 09, 2006 - 07:40:59 PM »
Diamond will sell direct check with them
Offline JimCuda
« Reply #9 on: November 09, 2006 - 09:22:16 PM »
Do you think my machine shop would be able to get a better price on these parts or should I get them myself?
« Reply #10 on: November 09, 2006 - 09:47:40 PM »
Virtually any machine shop has to charge for odering your parts , it takes time out of their day to do it
So anything you can do should save some $$$
Offline JimCuda
« Reply #11 on: November 09, 2006 - 10:14:42 PM »
Good point. I will try to piece together a final rotating assembly Friday/Sat and post it here to all to review.
Offline 1 Wild R/T
« Reply #12 on: November 09, 2006 - 10:29:29 PM »
But on the flip side if you supply the parts they will have no obligation to help you if a problem comes up...
Offline JimCuda
« Reply #13 on: November 09, 2006 - 10:41:04 PM »
Also a good point, and point taken.
I however I would think a good parts supply company like Summit, Jegs, etc would stand behind what they sell. Blems happen however you would think a good machine shop would let you know of bad parts before they hack them up. I plan on being there when they do my balance work.
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #14 on: November 09, 2006 - 10:46:15 PM »
If not to concerned about price, I talked to JE while at the SEMA show and they have a piston for 340's that give good compression and are good for forced induction if you decided to do that later whether it be turbo supercharger or nitrous.
1996 Dodge Viper GTS Coupe
