Author Topic: Correct fan for 70 Barracuda, 383, 22" radiator with shroud??  (Read 1563 times)
Offline OzCuda
« on: August 21, 2006 - 04:46:59 AM »
Chrysler Muscle Car Parts Interchange lists # 2863216 (7 blade 18.5") as the correct fan for a 70 Barracuda with 383.  Just after confirmation that this is correct.  Apparently the 22" radiator was available with 383's so I am upgrading its core (was a 318 car) and have bought the shroud to match.
I notice that there are other 18" 7 blade fans available - do people use these (I'm guessing most people use the 26" radiator though).
'70 Barracuda
Offline 70RAGTOPR/T
Re: Correct fan for 70 Barracuda, 383, 22" radiator with shroud??
« Reply #1 on: August 21, 2006 - 10:44:32 AM »
OZ.............Is your 383 the magnum engine, because my 383 takes a 26" radiator.
Offline FY1Challenger
  • I'm a llama!
« Reply #2 on: August 21, 2006 - 11:38:45 AM »
383HP, Non a/c, non HD cooling, takes 22" radiator w/shroud and the fan # you listed above. Straight out of the 1970 CC FSM.  :dunno:
Offline moparnut
    • My Photo's
« Reply #3 on: August 21, 2006 - 06:34:40 PM »
My GC is 383 magnum with 22" rad,I wish it was a 26"
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline OzCuda
« Reply #4 on: August 21, 2006 - 07:52:17 PM »
thanks guys, 26" radiator probably would have been a better option given I have 2 quotes both around $900 AU to have the 22" recored to handle the heat.  Anyone have thoughts on which is better 3 core with 18 fins per inch or 4 core with 14 fins per inch?
'70 Barracuda
  • I'm a llama!
« Reply #5 on: August 22, 2006 - 12:22:48 PM »
My car seems to do fine @ 95 F plus with the three core even in high humidity.
Offline 426 pentastar
« Reply #6 on: August 24, 2006 - 08:19:51 AM »
i wouldnt worry about it being concorse correct as i would having it run cool.i would use mopars five blade clutch fan which will help it run 30% cooler.
