Author Topic: Vapor Separator  (Read 980 times)
Offline Swissmopar
    • www.66plymouth.ch
Vapor Separator
« on: August 21, 2006 - 04:52:21 AM »
Hi,
I am new in your Forum - I am a Mopar enthusiast from Switzerland, owning a MN 1970 AAR Cuda and a MN 1970 Challenger R/T 383ci. Both cars were imported from LA to Switzerland. For the 1970 Challenger R/T 383ci I am missing the original vapor separator (in the trunk). The gas tank has 4 exit lines and parallel to the fuel line runs a second line to the breather on top of the right valve cover.
What kind of vapor separator do I need? Where can I get one? How are the lines connected (rubber tubes? clips? clamps?)?
Thanks for your help!
Regards,
Karl
Re: Vapor Separator
« Reply #1 on: August 22, 2006 - 12:01:15 AM »
unless the cali cars were different [I know they wee ] the 4 line gas tanks were used in 71 & later , you should be able to use a 71 system in the car if you can locate 71 parts to use , the 71 had the second breather line to the valve cover
Offline heminut
Re: Vapor Separator
« Reply #2 on: August 22, 2006 - 08:16:50 AM »
My 70 Cuda is a Cali car and came with the 4 line vent.
1970 5.7 Hemi Cuda
Offline pandamarie
  • I love YaBB 1G - SP1!
Re: Vapor Separator
« Reply #3 on: August 22, 2006 - 08:42:32 AM »
My 70 challenger has the vapor recovery system on it too. they used rubber lines to connect them and mine had crimp on clamps untill I had to replace all the lines. check here for a rplacement seperator for the trunk.  themoparshop.com trying to find the valve cover cap might be a problem though, it took me 2 years to find the correct one.
1938 packard 120
1948 lincoln convertible coupe(1 of 16)
69 charger
70 challenger R/T 440 6 pac
71 challenger 340 R/T 4 speed
2-1961 nash metropolitans
forgive wifes 75 vette
2002 dakota 4.7
