Author Topic: Cuda trunk gas filler neck help  (Read 1357 times)
Offline moparnut
    • My Photo's
« on: August 23, 2006 - 08:19:19 AM »
Could someone please post a pic of their gas filler neck pipe from inside their trunk?I forgot where it goes after replacing the trunk floor,thanks
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline ShelbyDogg
Re: Cuda trunk gas filler neck help
« Reply #1 on: August 23, 2006 - 11:27:58 AM »
I did the same when I put in my floor. I used the filler neck, held up to the hole, rotated around a little to see the correct angle, then started gringing the hole out with a die grinder.  I also installed the tank from below to eyeball the angle.  I kept enlarging the hole till the filler tube lined right up.    Funny thing is, the old hole was HUGE and when you get a new rubber boot, you'll  see how big that hole can be and still be covered.  I can send up a pic of the smaller hole after I get home if you still aren't sure.
Offline moparnut
    • My Photo's
« Reply #2 on: August 23, 2006 - 08:35:30 PM »
Thanks Dawg,if you got a pic that would help :ylsuper:
Offline ShelbyDogg
« Reply #3 on: August 23, 2006 - 09:59:28 PM »
Here's all I drilled out on my cuda for the tube to fit. When you put on the boot, you may want to grind it all the way out, so that you aren't left with a lip to hold water.  If you look at the 3rd pic, you'll see the outside lip on the boot. The hole should end up at this lip. I didn't put my tank in till all of my rear welding and grinding is finished.
Offline moparnut
    • My Photo's
« Reply #4 on: August 23, 2006 - 10:12:51 PM »
thanks bud,so it goes right behind the rear light panel?I still have to weld in the trunk latch assembly.The only thing nice about the final assembly(after more than a year being apart)I have my chally sitting right next to it for reference,most of the stuff should mount simularly,like firewall components ect
Offline ShelbyDogg
« Reply #5 on: August 24, 2006 - 06:14:01 AM »
Yes, the flat spots are for the filler in either the Cuda or Challenger. You can cut that hole and line up the filler before you weld in the trunk latch mount. I use a die grinder to quickly eat away the metal from the topside.
Offline moparnut
    • My Photo's
« Reply #6 on: August 24, 2006 - 08:39:53 AM »
Thanks again Rob,I usually use my Greenlee sheet metal knock out set,works great for a nice clean factory looking hole.
http://www.greenlee.com/cat_docs/Holemaking.pdf
This is a PDF page so you have to wait to D/L it,if interested
 :thumbsup:
Offline ShelbyDogg
« Reply #7 on: August 24, 2006 - 08:45:22 AM »
Yeah, I've used those punches for my electronics projects but that filler hole will end up being an oval about 4"x6".
Try the Die grinder with a barrel shaped carbide tip. It cuts that steel like a hot knife through butter.
Offline moparnut
    • My Photo's
« Reply #8 on: August 24, 2006 - 10:30:13 AM »
I have several of those die grinder tips,thanks
One day I will invest in a plasma cutter
Offline LugNut
  • Future 50 footer 'Cuda
« Reply #9 on: August 27, 2006 - 06:09:52 AM »
Here's a low-res pic from eBay of a NOS trunk floor pan with what looks like the factory hole.  It's very large and oval.
My trunk floor was almost completely gone, so I'm facing the same problem.
 :bananasmi   LugNut    :bananasmi
My '71 'Cuda Restification pages:
(Down for a quite while; changed ISPs twice)
The 1964-1974 Barracuda Web Ring home page:
(Was the last ringmaster; RingSurf is currently a zombie host)
Offline moparnut
    • My Photo's
« Reply #10 on: August 27, 2006 - 07:46:18 AM »
thanks :thumbsup:
Offline gb623
« Reply #11 on: August 27, 2006 - 10:56:35 AM »
Heres a pic of mine , whats left. Pretty big.
