Author Topic: Dash removal  (Read 1764 times)
Offline bullfrawgs
  • I'm a llama!
Dash removal
« on: June 27, 2003 - 10:08:09 AM »
Is it possible to pull out the entire dash assembly as one piece? I want to leave all wires and guages attached. It is a non ac 73 challenger. I need to get to the cowl vents and fix them and also got some minor rust to fix.  What reference materials would show removal and installation?
Re:Dash removal
« Reply #1 on: June 27, 2003 - 02:21:20 PM »
Yes it is relatively easy to do , there are 6 bolts , 4 in the defroster vents & 1 at each end by the kick panel , you also need to pull the firewall plug , disconnect the vent cables & heater cables & drop the column as the dash is pinched between the column & pedal support
lemonboy69
Re:Dash removal
« Reply #2 on: June 27, 2003 - 11:48:24 PM »
It's really hard to get to the ones in the defroster vents with the front windshield in... I don't know if you want to go through the effort of pulling it... but from experience... with it out... those 4 bolts are sooooo easy to get to... ::) Good luck!
LB
