Author Topic: Shaker Hood Air Cleaner Removal  (Read 2765 times)
Offline joemcarroll
  • Newbie
« on: August 24, 2006 - 07:59:26 AM »
At the risk of sounding stupid, I need to know how to remove the shaker hood air filter assembly off my 1970 Dodge Challenger T/A Converible.  It's a 426 hemi crate motor with a stock '70 shaker hood set-up.  I just picked the car up this weekend, have never had a shaker set-up before.
Offline Blackcuda
Re: Shaker Hood Air Cleaner Removal
« Reply #1 on: August 24, 2006 - 08:07:25 AM »
The bolts around the outside lip need to be removed and you can lift off the shaker, from there it's easy to remove the airfilter assembly.
Offline 426 pentastar
« Reply #2 on: August 24, 2006 - 08:15:05 AM »
first you need to remove the bolts that hold the shaker bubble down,then check to make sure it has control cables which it should,you will need to disconnect the cable going to the vent doors on the shaker,lift the bubble and remove the cable from the base and bingo there it is.
Offline 4Cruizn
  • HEMI FISH
« Reply #3 on: August 24, 2006 - 08:34:21 AM »
 :iagree:   Love to see some pics!!!  Welcome aboard!!   :wave:   :wave:   :wave:   :wave:   :wave:   :wave:   :wave:
Offline joemcarroll
  • Newbie
« Reply #4 on: August 24, 2006 - 08:37:41 AM »
Thanks for the very good advice.  How are vent doors on the shaker unit controlled?
« Reply #5 on: August 24, 2006 - 09:56:54 AM »
there is a cable under the dash to the belcrank on the shaker base , as 1 door is opened with the belcrank the other door is closed off
