Author Topic: 833 OD Transmission problem will not shift into 1 or 2nd gear  (Read 1454 times)
Offline 71340RT
« on: August 25, 2006 - 11:57:41 AM »
I've got my engine and transmission put back into my 70 340 Cuda and now that I've been hooking everything up I got to the shifter and linkage and it will not shift into 1st or 2nd gear. It shifts into 3rd, 4th and reverse but will not shift into 1st or 2nd gear. I took the linkage off and tried to put it in gear on the side of the transmission and it will not move. This is a rebuilt 833 OD transmission I picked up a mopars at Indy and it shifted into all the gears when I got it. I have put a new side cover gasket on as it was missing and thought it was all put together correctly with the interlock levers but will not shift now. If anyone has ran into this issue let me know the fix so I can start my new engine and drive the Cuda again.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline ShelbyDogg
Re: 833 OD Transmission problem will not shift into 1 or 2nd gear
« Reply #1 on: August 25, 2006 - 01:15:32 PM »
Jeff,
You're going to have to pull off that side cover and see what you did.  There's no other answer to your question.
Offline 71340RT
« Reply #2 on: August 25, 2006 - 06:34:25 PM »
Jeff,
 Rob, I'll pull the cover off Saturday and see what I can find inside.
Jeff
« Reply #3 on: August 25, 2006 - 10:36:48 PM »
Jeff,
