Author Topic: 4 speed w/out 3rd or 4th gear??  (Read 1589 times)
Offline cudaaah
  • 71 HEMI cuda, 2015 ram 2500 mega cab diesal 4x4
« on: August 27, 2006 - 09:52:54 AM »
Took my Cuda out last night, stopped for gas, hit Hwy and couldn't get 3rd or 4th gear.  The shifter moves into position, but feels real loose.
My transmission is new from Passion Performance, and I just had it installed 6 mnths ago, I haven't had any problems until last night.  Maybe 200-300 miles on the trans.
Does this sound like it could be a linkage problem?
Cudaaah
Re: 4 speed w/out 3rd or 4th gear??
« Reply #1 on: August 27, 2006 - 10:02:31 AM »
yes , make sure the lever is tight on the side of the tranny
Offline cudaaah
« Reply #2 on: August 27, 2006 - 10:18:42 AM »
Thanks, I'll check it out this evening.
Offline ShelbyDogg
« Reply #3 on: August 28, 2006 - 12:12:04 PM »
Easy fix;
Sounds like you broke the fork off.  The brass ones shear right off.  Get a set of the late model steel forks and cut the tip off with a cut-off tool to use it on the old style side cover. You'll see what I mean when you get them. You want to always replace those brass forks anyway. At least you weren't racing it, without a rev-limiter, and end up bending all of your valves.
Edit:  If I were you, I would call Passon and ask for the steel forks.  6 mo. old isn't long enough.
« Last Edit: August 28, 2006 - 12:21:05 PM by shelbydogg »
Offline cudaaah
« Reply #4 on: August 28, 2006 - 04:32:06 PM »
You know, I believe I did get the upgraded fork...when I ordered the trans, he had mentions a stronger____, I think it may have been the fork.  I recall something being brass.  I don't know transmissions, but I did opt for the upgrade.  I didn't get a chance last night, but I'll check it out tonight.
Thanks
Cudaaah
Offline cudaaah
« Reply #5 on: August 28, 2006 - 04:58:23 PM »
Well it turns out the rod coming down to the trans from the shifter came off the trans.  Looks like there was a cotter pin opened up and slid through the hole and twisted to hold it on.
Fortunately I think I can fix it tonight.
Thanks for the help.
« Reply #6 on: August 28, 2006 - 11:50:00 PM »
Hurst still has the correct wrap around spring clips which work a lot better then the cotter pin
