Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
Changing Radiator
« previous
next »
Print
Pages: [
1
Author
Topic: Changing Radiator (Read 1733 times)
trouble
Jr. Member
Changing Radiator
on:
August 27, 2006 - 10:29:32 AM »
I just received my radiator from Harms Auto.I have never changed a radiator,is it a pretty simple process?
Thanks Al
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Changing Radiator
Reply #1 on:
August 27, 2006 - 11:01:25 AM »
yes , drain the coolant , undo the hoses & tranny lines & shroud if you have one & remove the 2 top bolts , loosen the 2 bottom bolts & the rad will slide otu
Logged
trouble
Jr. Member
Reply #2 on:
August 27, 2006 - 11:17:26 AM »
I'm going to replace it next week,thanks Al
Logged
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Reply #3 on:
August 27, 2006 - 11:59:18 AM »
Al,
If you are afraid to give it a shot, I can always put that in my car.
Good luck with it.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
trouble
Jr. Member
Reply #4 on:
September 29, 2006 - 02:39:44 PM »
:clueless:I finally got around to changing my Radiator.Can someone tell me how much anti freeze and how much water it takes.
Thanks Al
Logged
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Reply #5 on:
September 29, 2006 - 02:50:37 PM »
All Depends on the motor & radiator capacity & that can vary somewhat. What I do is buy two gallons of Coolant concentrate put one gallon in + one gallon water. use the empty jug to measure out a half gallon then fill the two halves with water so I have two gallons 50/50 mixed, then keep adding warming the motor as I go till she's full.
FYI a 73 400 w/ac 18 quarts a 318 16 quarts ..
50/50 mix generaly good to -32 the coolant label should tell you.
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
trouble
Jr. Member
Reply #6 on:
September 29, 2006 - 03:29:36 PM »
My car is a 440 6pack with a 26" radiator.I already put 2 gallons anti freeze ,1 gallon water and the radiator is filled.
Logged
Bullitt-
Permanent Resident
Reply #7 on:
September 29, 2006 - 04:47:14 PM »
Have you started the car & let the coolant circulate to get air out of the motor? did you drain the motor completely or just the radiator. to begin with?
Logged
Huntsville, AL
trouble
Jr. Member
Reply #8 on:
September 29, 2006 - 04:56:08 PM »
I only emptied the radiator.I just took the car for a ride with the heat on.When it cools down I will check it again.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Changing Radiator
