Author Topic: 70 Cuda is up and running without any problems  (Read 2163 times)
Offline 71340RT
« on: August 27, 2006 - 10:42:15 PM »
I finally got the Cuda fired up Saturday and took it for it's first test run with the rebuilt overdrive 4 speed and fresh rebuilt 340 on Sunday. To say I'm thrilled with the overdrive would be a under statement. It shifts like a dream and the gear spread seems to be just right for the 70 340 I just got through rebuilding. The only problem I ran into starting up the engine was I had the distributor 180 degrees out and it would not hit a lick. Once it was put the distributor in right, I put the lock down on the distributor where it was when I took it apart it fired right up. The timming was dead on and the alternator was working hard charging as the battery had set for 9 weeks and I never thought about putting my trickle charger on it to make sure it had a full charge. I drove the Cuda about 30 miles today with no problems at all. It drove great and seemed to run very good for the fresh engine. The overdrive transmission shifts smoothly and I'm glad this is the route I chose as I enjoy driving my cars and I just felt I wanted to let the engine run a little lower rpm and maybe gain some gas mileage at the same time on the open road. The engine is a .40 overbore with X 2.02 heads and stock intake and exhaust manifolds. I did put a crane energizer cam kit in but small enough so the power brakes will work fine. The weather looked like rain so I put it away for another day. I would of loved to of just kept driving as the Cuda has been down since I spun a rod bearing coming back from the Show Me Mopars car show in June with 721 miles on the rebuilt engine. I took a couple pictures after I put it away and will attach them.
Jeff
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline Carlwalski
Re: 70 Cuda is up and running without any problems
« Reply #1 on: August 28, 2006 - 02:25:05 AM »
Awesome stuff! It's a lovely looking Cuda mate, I'd love it in my garage.  :droolingbounce:
 :cheers:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #2 on: August 28, 2006 - 09:00:53 AM »
 :woo: :woo: :woo:  Good news for sure!  I bet that was a great drive!
Offline KillerBee
« Reply #3 on: August 28, 2006 - 11:32:27 AM »
Car looks great :thumbsup:
Who did the tranny rebuild? Passions?
What rear gear are are running?
Offline loco340cuda
« Reply #4 on: August 28, 2006 - 12:25:07 PM »
What is the cam part number that you used?
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Offline gb623
« Reply #5 on: August 28, 2006 - 08:12:58 PM »
 :cheers: Thats the day I'm dreaming about.  :burnout: Nice looking engine bay. :cooldancing:
Offline Street_Challenged73
« Reply #6 on: August 28, 2006 - 10:26:26 PM »
Glad everything worked out well for you! :cheers: :woo:  That's a very nice looking setup you have under the hood!!! :drool:
Offline 71340RT
« Reply #7 on: August 28, 2006 - 11:03:27 PM »
The part number for the cam kit is 150052. This is there energizer matched cam and lifter kit. The specs are Lift int .454 exh .454 and duration at .050 int. 216 exh 216
Offline 71340RT
« Reply #8 on: August 28, 2006 - 11:05:59 PM »
  The transmission was built by a rebuilder north of Indy in Indiana and I'm running 3.23 gears in the rear end.
Offline jvike
  • Pro-Touring Cuda
« Reply #9 on: August 29, 2006 - 03:47:00 AM »
That is one perfect 'Cuda you got there! Congrats  :picture:
Offline cudabuyer
« Reply #10 on: August 29, 2006 - 05:13:15 AM »
 :wow: :wow:
BEAUTIFUL - CONGRATS
70 Dodge Challenger Convertible 6.1 Hemi
Offline loco340cuda
« Reply #11 on: August 29, 2006 - 09:13:33 AM »
Thanks for the info.  That cam is almost the same specs as the Comp Cam I am running in my 340, int .454 exh .454 and duration at .050 int. 218 exh 218.  I am also running 3.23's gears with a four speed.  What tire size are you running?
Also I forgot to complaiment you on how nice your car is.  Love the clean engine compartment.  :2thumbs:  The picture you posted above is exactly how I hope my engine compartment looks when I get my car redone in the future.
crazy larry
« Reply #12 on: August 29, 2006 - 10:18:46 PM »
Nice super clean :money:
Offline 71340RT
« Reply #13 on: August 30, 2006 - 08:55:38 AM »
Thanks for the complements. I rstored the engine compartment back to bone stock. I'm running 14X6 rallyes wheels with 225X70 14" on the Cuda but will up grade to the correct 15X7 rallyes sometime soon as this is what came on my Cuda.
Jeff
kudakidd
« Reply #14 on: August 30, 2006 - 04:44:24 PM »
Sweet lookin ride. You must be pumped! :bananasmi
