Author Topic: Painting PPG on top of Dupont?  (Read 1136 times)
Offline tactransman
« on: August 28, 2006 - 06:50:52 AM »
Any problems with putting PPG  BC/CC over Dupont BC/CC that was sprayed over 2 years ago? I can get PPG for $238 a gallon now where the Dupont is $389 a gallon. I have to respray this thing from bumper to bumper when I get it all assembled.
« Last Edit: September 16, 2006 - 06:01:34 PM by tactransman »
Terry-tactransman
Union, Mo.
Offline bigblock4speedman
Re: PPG over Dupont?
« Reply #1 on: August 28, 2006 - 07:18:16 AM »
As long as the last job was done right and the DuPont bonded well, and is not peeling.  It should be fine to scuff, clean with wax and grease remover and shoot PPG epoxy primer and paint.  That's hard to believe that DuPont is higher than PPG, PPG is better!
Offline AAR71
« Reply #2 on: August 28, 2006 - 09:00:05 AM »
 :working:
               Do your prep work i.e dull the old paint and degrease everything then shoot a primer sealer over the whole car so there is no chance of interaction between the two paints cause you never know and its better to be safe than sorry then block sand your primer degrease again and begin shooting the paint. Hope this helps.
Offline Skeletoil
« Reply #3 on: September 14, 2006 - 07:42:47 PM »
You can use enamels over enamels, sealer is always recommended. If the paint is over 90 days old you shouldn't need it but it is good insurance against lifting the previous paint. Even sealer won't help if you slam on 2 heavy coats real quick. Easy on the first and second coat. Allow plenty of flash time. If the paint is still fresh say within 90 days and you put a Urathane paint over an enamel you can expect trouble.
Offline cudagirl4406pk
    • Garageartmusclecars
« Reply #4 on: September 15, 2006 - 10:05:19 AM »
My husband uses PPG or house of kolor he likes them better.Also he says use a sealer or reprimer to keep the paints for interacting to prevent the lifting.
Offline tactransman
« Reply #5 on: September 15, 2006 - 10:12:09 AM »
Well , I think I have found out that that cheaper price for PPG was for a cheaper brand of PPG. The PPG brand equal to the Dupont I was using is about the same price, so ......... I will just get the same Dupont that I bought the first time and won't have to worry about any "reaction" :thumbsup:
Terry-tactransman
Union, Mo.
Offline gomangoRT/SE
« Reply #6 on: September 15, 2006 - 09:39:32 PM »
I got a quote last year from a PPG store for gomango and my cost for a gallon was about $240 a gallon
« Reply #7 on: September 15, 2006 - 09:54:30 PM »
PPG, it's the best.
Offline 71340RT
« Reply #8 on: September 15, 2006 - 11:44:18 PM »
I have used both and would have to say I like PPG over dupont as it seems easier to use and always has a great shine. I put it on both my Challenger RT and my cuda.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline JCWCuda
« Reply #9 on: September 16, 2006 - 05:51:31 PM »
I too am a big fan of PPG , I have used a lot of the Deltron Line Base/Clear and find very easy to use . I have also used there one step on some small projects and was happy with the outcome .
1974 Barracuda 360
2008 Ram 1500 Quad Cab 5.7l Hemi
1990 Jeep Cherokee 4.0l
Gone but not forgotten
1967 Barracuda 273
1976 Charger 318
2003 Dakota Quad Cab 4.7l
1988 Jeep Cherokee 4.0l
