Author Topic: Whats the Prob?  (Read 1101 times)
Offline moparnut
    • My Photo's
Whats the Prob?
« on: August 31, 2006 - 06:53:40 PM »
When i hook up the vacuum on my 340 engine runs crappy,unhook it and runs good.Is the dist vacuum pot the prob?
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline Challenger6pak
Re: Whats the Prob?
« Reply #1 on: August 31, 2006 - 07:01:10 PM »
Sounds like a good possibility.  You are causing a vaccum leak when it is hooked up due to it's leak.
Offline moparnut
    • My Photo's
Re: Whats the Prob?
« Reply #2 on: August 31, 2006 - 07:04:34 PM »
I will change that,they are cheap
Re: Whats the Prob?
« Reply #3 on: August 31, 2006 - 11:44:09 PM »
you are connecting it to manifold vacuum & advancing the timing at idle wrong way  you need to hav eit connected to ported vacuum if you use it at all , I never hook it up on my cars
Offline moparnut
    • My Photo's
Re: Whats the Prob?
« Reply #4 on: September 01, 2006 - 10:12:56 AM »
thanks CHyrco,saved me time and money again!I'll just leave it unhooked
Re: Whats the Prob?
« Reply #5 on: September 01, 2006 - 03:06:48 PM »
Assuming you did connect it correctly, you should only see the car running badly, or missing while it's at cruising speed. At idle and under full throttle, the vacuum advance should not be a factor. Is that the case here? My car would "miss" at cruising speed, as my vacuum advance was advancing the timing too much. You can use an Allen wrench to adjust the pod so it doesn't advance so much... but I ended up doing what Chryco suggested. If you go that route too, be sure to plug that port on your carb so you aren't sucking in unmetered air.
Offline moparnut
    • My Photo's
Re: Whats the Prob?
« Reply #6 on: September 01, 2006 - 04:22:47 PM »
I did connect it to the right place and plug off the carb hole,ran crappy at idle.I am pretty good at tuning a car,just a little rusty.So now your telling me i suck unmetered air?what kind of an insult is that?I would expect that from ShelbyDawg and not you,lol.I'm just kidding around,I am just feeling a bit ornery and stoked to have a 4 day weekend :bigsmile:
Re: Whats the Prob?
« Reply #7 on: September 01, 2006 - 04:30:09 PM »
OK,
  You had me scared. I thought I insulted you.  :o  :o  :o
  If your car runs crappy at idle, it can't be that your vacuum advance, advancing the timing too far. Yes, a leaky pod would, so maybe that is the problem here?  :dunno:
« Last Edit: September 01, 2006 - 04:37:58 PM by MEKrunner »
Offline moparnut
    • My Photo's
Re: Whats the Prob?
« Reply #8 on: September 01, 2006 - 07:45:38 PM »
Sorry I was just having a little fun,still waiting for Shelbydog to chime in :bigsmile: :stirpot:
Offline ShelbyDogg
Re: Whats the Prob?
« Reply #9 on: September 04, 2006 - 09:12:42 AM »
Thanks Moparnut,
Put a hose on the pod and suck it while watching your timing with a timing light. It should advance. If it leaks you'll feel the hole let air in after you suck it then block it with your tongue.
I always use manifold vacuum. It will allow your engine to idle smoothly and give you better throttle response and gas mileage.
Get that timing light out.
