Author Topic: Are all 440 six packs created equal?  (Read 3630 times)
Offline focal 7
« on: September 01, 2006 - 09:06:40 PM »
I have a 1970 six pack long block and have located a 6 pack intake system for it complete with air cleaner and linkage. My question is, are there date codes for the 6 pack systems themselves? How do I know that it will match? Are there numbers on the carbs or manifolds? I need help. Thanks in advance!
Alaskan_TA
Re: Are all 440 six packs created equal?
« Reply #1 on: September 01, 2006 - 09:14:30 PM »
The carbs are date coded, I believe the iron sixpak intakes have date codes, but the aluminum ones do not.  :dunno:
I know the small block ones do not have date codes for sure.
Offline Cuda Cody
  • Vancouver, WA
« Reply #2 on: September 01, 2006 - 09:28:52 PM »
All 3 carbs will have the 4 digit date codes on them.  They will be all very close in the dates.
4 digit codes are like this.... 2359 (235th day of 1969)
Offline Green Drop Top
« Reply #3 on: September 01, 2006 - 09:30:11 PM »
Yes, iron intakes are date coded. Yes, the carbs are as well, and the center carbs are quite specific to each year and transmission application, in addition there's a special group of carb numbers that were California only (emmissions). As far as performance I'm pretty sure all of them were basically the same carb with minor jetting differences.
Offline Plum6Pak
  • Plum6Pak
« Reply #4 on: September 01, 2006 - 09:55:11 PM »
Hey Focal, that will be sweet once you get it set up, just curious, how can you tell it's a 6pak long block? I've always wondered how you can tell it's a 6pak engine other than the forged steel crank that's internally and externally balanced and has the weighted harmonic balancer. When they'd build a 6pak engine, they'd just grab an HP block and build it up as the 6pak but I don't believe there is a way to tell by the numbers. Is the manifold you located aluminum or cast iron? I believe the first generation (69-1/2) 6pak setups were aluminum, after that I believe they were all cast iron but will still have the date codes.
Offline focal 7
« Reply #5 on: September 01, 2006 - 10:08:47 PM »
Plum6pak,
   Now you got me there on the numbers thing, I'm not sure either. But as for this motor, it came out of a wrecked 70 superbee in 1979 and it was a 6 pack car, so that's how I know. It does indeed have the proper crank, rods, damper, heads, etc. The manifold that I am looking at is cast iron. I wish I could find out the exact numbers I need for the intake and carbs......anybody got em!   Thanks
« Reply #6 on: September 01, 2006 - 11:14:31 PM »
the iron intakes were used in 70/71 , alum was used in 69
 the carbs will have a 4 digit date # on them ex 2859 ,which is 285th day of 69 79 89 99
« Reply #7 on: September 02, 2006 - 01:29:08 AM »
I need some original 70 carbs for my 70 440 +6 Cuda, mine was a California car so I need the funky emissions CA only center carb (#4144) and the two ends carbs #4383 (rear) and #4382 (front).
If you happen to have those I'll replace them with all brand new ones as trade!
 :burnout:
*BTW, some early build date 1970 cars recieved leftover aluminum intakes.
« Reply #8 on: September 02, 2006 - 02:26:30 AM »
I thought about buying a new set in late 99 with the correct date code !!
Offline trouble
« Reply #9 on: September 02, 2006 - 10:38:08 AM »
This is a center carb with date and number.I'm not sure what the number on the bottom of the carb is.
« Reply #10 on: September 02, 2006 - 10:49:28 AM »
Yep, that's a 1970 440+6 manual transmission center carb manufactured the 283rd day of 1969 (September/October or so).
Here's where to look for the numbers which are stamped into the top rear sides of the upper air horn areas.
« Last Edit: September 02, 2006 - 11:13:24 AM by Harms inc. »
Offline trouble
« Reply #11 on: September 02, 2006 - 06:00:36 PM »
Thanks for telling me what the numbers 2839 are.My 6 pack manifold has a date stamped on it, but no manifold number.Should it have a manifold number on it?thanks Al.
Offline focal 7
« Reply #12 on: September 02, 2006 - 06:32:07 PM »
VERY,  VERY helpful.....thanks to all   !!!
« Reply #13 on: September 03, 2006 - 02:09:37 AM »
usually there is a casting #
« Reply #14 on: September 03, 2006 - 08:22:58 AM »
Trouble, what's teh casting date on your intake?
