From Engle I would look at K58 /K60 -114* CL cam or a K60/K62 114*cl
I feel your compression may be too high to run 10 Psi boost witout octane boost but it may work out , I know you have better fuels in Europe
at 6500 RPM you are at or just past the reliable limit of hyd cams / lifters & may have stability problems , but going to a solid cam will require pushrods & mechanical rockers which will cost more
UltraDyne has a 243 * duration cam with .548 lift with 1.5 rockers + approx .38 extra lift with 1.6 rockers , you will also need it ground with a 114* Cl , they can be ordered through Lunati
hi chryco psycho
thanks for you answer !
have already now mechanical rockers
so a solid cam is no problems
the custom cam from engle
k58/k60 ,114ci =in520 lift / exh534 lift
k60/h62 114 ci= in539lift/exh557 lift
right or ? (neede more exh lift with boosted right?)
what about intake m1 or Edelbrock performer rpm, ?
you se my combo about
what is your idea ( use the car only for fun mainly in weekends )
prices for custom cam ?
thanks
hope you can understand my english
best regards
torben
