Are the K&N air filters worth it?
Author Topic: Are the K&N air filters worth it?  (Read 1982 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: September 03, 2006 - 08:38:50 AM »
Are the K&N air filters worth it? I'm thinking of buying one to get as much air in the carb as I can. The aif filter I have now  is 3 inch raised. I was thinking of 4 inch droped, but is the extra inch at any use then? And should I get the one with or without air flow top?
« Last Edit: September 03, 2006 - 08:42:26 AM by widing'cuda »
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Offline heminut
Re: Are the K&N air filters worth it?
« Reply #1 on: September 03, 2006 - 09:17:54 AM »
Definately worth it. They flow much better than any paper filter out there and you'll never have to replace it. I have K&N filters on everything I own. If you want the most air flow you can get then get the top to, but if your not racing the car I wouldn't worry too much about using the K&N top, it would just be overkill. BTW, I have a K&N 14X3 air filter that I've had for 20 years that has been on 3 different vehicles (I get rid of the vehicles but keep the filter!  :grinyes: ) and it's still in great shape!
1970 5.7 Hemi Cuda
Offline widing'cuda
« Reply #2 on: September 03, 2006 - 09:42:52 AM »
That's great to hear, I'm defiantly going to get one.
The closest I'll be to racing is red light drag racing.  :thumbsup:
Offline Dragula
« Reply #3 on: September 03, 2006 - 09:20:01 PM »
If your carb is tuned to a restrictive air filter, and removing the air cleaner affects idle or overall performance, you might have to rejet a little. One of these little babies actually helped me with a carb issue on my fiance's car. I rebuilt the holley that was on it, and no matter what I did, it went rich after ptting the air cleaner on. So I bought her one the K&N's to fit the stock snorkle air cleaner and wella, all better.
Offline BIGSHCLUNK
« Reply #4 on: September 03, 2006 - 09:40:11 PM »
Question, we were just talking filters tonite. We were at a friends B-DAy party and he had the type of air cleaner on a motor he built that was on LUMPY"S R/T SE... the one CODY bought. And I remember what happened to Cody's car when it backfired though the carb. Would one of those K&N's with the top flow stop a backfire??   :scared:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #5 on: September 04, 2006 - 12:41:41 AM »
I am not sure if it would stop a real bad backfire, but they do have a metal mesh which should stop a mild backfire, but there is also a chance of messing up the gauze element.
« Reply #6 on: September 04, 2006 - 05:44:12 AM »
My plan is to use a K&N in a stock breather box. I have researched & found a taller one for a 77 Newport that I believe will work.
  I changed to k&n in my 4.6GT & it mad a noticeable improvement.
« Last Edit: September 04, 2006 - 04:44:12 PM by bullitt99 »
Offline jvike
  • Pro-Touring Cuda
« Reply #7 on: September 04, 2006 - 07:26:13 AM »
Both me and my brother use K&N filters with a filter top, works great! But we both have functional hoodscoops. I've got an AAR hood, and he has cut a hole in his hood to get the Mustang Mach1 scoop functional.
« Reply #8 on: September 04, 2006 - 11:15:33 AM »
Don't ask... but I had flames coming out of my carb.  :22yikes: I put the K&N on it REAL fast, and it snuffed it out. Lesson learned... don't ever try to start your car without an aircleaner assembly on it.
Like jvike, I have a functional hood scoop, so I think the airflow top helps a bunch.  :thumbsup: Yep, they are a bit pricey though.
Offline widing'cuda
« Reply #9 on: September 04, 2006 - 04:10:58 PM »
So the air flow top is no use on an normal rally'cuda hood? Is there anyting negative about using the air flow top compare to without air flow top on a normal hood? As I think the air flow top really looks cool  :ylsuper:
« Reply #10 on: September 04, 2006 - 04:48:15 PM »
Widing'cuda I think the concern is with a carb fire that the oil soaked guaze top can be a fire hazard. CODY had a foam air cleaner that went up in flames when his carb backfired.
Offline GoodysGotaCuda
« Reply #11 on: September 04, 2006 - 05:07:43 PM »
Its not quite 'no use', it will give you 'that' much more surface area to suck air from. It will of course be more effective with a scoop/cool air flowing over it..
When it comes time, ill prolly slap a replacement k&n for my ram-air setup. Can't see why it'd hurt.  :thinkerg
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 422STROKER
  • Member Since 6/3/06
« Reply #12 on: September 04, 2006 - 05:52:10 PM »
Prolly get you in th 13's!
Tom :bigsmile:
Tom
« Reply #13 on: September 04, 2006 - 05:57:38 PM »
Tom :bigsmile:
The ram air is new since the 14.0/last time out.  :bigsmile:
1976 Dodge Warlock
Offline 422STROKER
« Reply #14 on: September 04, 2006 - 06:06:20 PM »
That'll prolly get you there.  Nice mod a K+N wouldn't hurt there.  Hey do you have that Vacuum Flapper stuck open?  Or is it Open all the time?  Just wondering, that looks good.
Tom :2thumbs:
Tom
