Author Topic: Ever feel like you want to push your car off a cliff?  (Read 7867 times)
Re: Ever feel like you want to push your car off a cliff?
« Reply #30 on: September 07, 2006 - 08:42:26 PM »
Codeman, sounds like your making progress, before you stated it would NOT run under 13k now you say it's rough under 11K soooo may be down to a few carb adjustments (let's hope so)  At my last club meeting we were given a lesson in carb.101 it seems that getting a motor to idle & come off idle smoothly  must be the hardest trick in the bag. I suppose when you lean the carb. you are referring to the mixture screws on the idle circuit. Does this effect the RPMs or smooth out the idle? If your running at 11K you are somewhat off the idle circuit & getting into the idle transition stage where fuel is being sucked thru another opening & this is effected directly by the float level. So if you have no vac. leaks float level is my guess. see link for further clarification.
http://www.chevyhiperformance.com/techarticles/83118_carburetor_basics/
Offline 67Vette427
  • My other car is not a Rambler
« Reply #31 on: September 07, 2006 - 11:21:00 PM »
Did you do two compression checks, one with it at running temp and one when its cold? With the carb @ WOT?
What kind of cam is in the engine? Maybe your lifters are giving you problems?
Pull your rocker shafts and check to see if all the valves line up without big gaps.
You can run propane around the intake and check for leaks. If it sucks in the propane the rpm's will increase.
1 of 1 Mr Norm's T/A/ 2015 Hellcat, sublime/ 13 Power Wagon
« Reply #32 on: September 08, 2006 - 12:26:16 AM »
He did a compression test warm , it came up good within 10% or less
Offline 67Vette427
« Reply #33 on: September 08, 2006 - 01:04:53 AM »
Its going to be something silly, like low blinker fluid...
Offline MyMopar
« Reply #34 on: September 08, 2006 - 11:22:34 AM »
Thanks for all the help everyone and Mike you can have as much time as you want with my car.  Just clean her off when you're done.
That's just wrong.  :eek4:   :roflsmiley:
1969 (OO===]|[===OO)
1973 (OO/=====\OO) <---SOLD
1997 (O|||||O) <---SOLD
Smoke tires, not drugs!
Offline rallyechall
« Reply #35 on: September 08, 2006 - 01:03:21 PM »
Have you checked fuel pressure? We had a fuel pump eccentric bolt loosen up and the car would start, but not run at times. Sometimes if it caught, it would actually idle, but would not run when in gear. Pull the pump and look at the arm first. See what kind of shape it is in. If that looks normal, check the fuel pump eccentric. It may be heavily grooved, or the bolt may have backed out. Good Luck
crazy larry
« Reply #36 on: September 08, 2006 - 08:02:49 PM »
Buy high Sell low the storie of my life. So how much? :2cents:
Offline BIGSHCLUNK
« Reply #37 on: September 10, 2006 - 09:37:54 PM »
Cody I don't know to be happy or sad for you. Seriously I hope you get this starightend out. But at the same time I was looking at the car when you were... I think by now I'd have packed it full of C-4 and KABOOM!!!!
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline ShelbyDogg
« Reply #38 on: September 10, 2006 - 10:11:02 PM »
Cody,  I was thinking,  When you put on your intake, did you tighten the bolts side to side, starting in the middle?  Unless you have seen a manifold bolt tightening sequence diagram, you may not know of the proper order and created a vacuum leak.  If you tighten all on one side first, it happens. If you start on the ends, it does it.
« Reply #39 on: September 10, 2006 - 10:59:22 PM »
He did it right
Offline Cuda Cody
  • Vancouver, WA
« Reply #40 on: September 10, 2006 - 11:50:24 PM »
Thanks for all ideas and help.  The article on the basics of carbs was great!
When I get this car done it will be 10 times better than when I got it.   I just hate to cut corners and I'm not willing to do that with this vehicle.  So the engine will be getting a new cam, valve springs and some minor improvments to make it very dependable and drivable when it's done.  :woohoo:
Offline Grancoupe
« Reply #41 on: September 11, 2006 - 06:51:48 PM »
Any chance you got some bad gas? How many tanks have you been through since this started?
Offline Cuda Cody
  • Vancouver, WA
« Reply #42 on: September 11, 2006 - 07:55:08 PM »
That ran through my mind early on, however the car has ran good on the tank that is in there.  This is just a running to rich issue right now.  I have to figure out why it's running so rich.  The carb will not get down to an idle, so it's hard to do much vacuum testing.
The back two plugs are the ones giving me the trouble.  Within 10 min of running at 1,600 RPM they are completely covered in black (not oil) and will not fire very good.
I called Holley and they gave me a few ideas and things to check.  Early signs are looking very good!
« Last Edit: September 11, 2006 - 08:40:46 PM by C O D Y »
Offline Cuda Cody
  • Vancouver, WA
« Reply #43 on: September 18, 2006 - 05:54:43 PM »
Holley finally ran out of things to have me buy and replace.  The carb went back today to be flow checked and tested.  We'll see what they say when they get it on their bench.  :clueless:
« Reply #44 on: September 18, 2006 - 06:26:48 PM »
Ever try the Eddie again?
