70 cuda trunk lock rod cover, what size bolts to use?
Author Topic: 70 cuda trunk lock rod cover, what size bolts to use?  (Read 1212 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: September 04, 2006 - 12:43:18 PM »
On my 70 'cuda the trunk lock rod cover was missing and I just got a hole of one. What size bolts should I use? As I have to special order bolt in inches in Norway, as we use cm.
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Offline GoodysGotaCuda
Re: 70 cuda trunk lock rod cover, what size bolts to use?
« Reply #1 on: September 04, 2006 - 01:21:52 PM »
my 72 had just some sheet metal philips head screws. I have no reason to think they werent factory.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline widing'cuda
« Reply #2 on: September 04, 2006 - 02:01:17 PM »
It's not screws as there are bolt hole in the right taillight for it. And on the rod that goes over the filler neck/holds the trunk locking mechanism. I think this is a 70 only ting....
« Last Edit: September 04, 2006 - 02:12:31 PM by widing'cuda »
Offline 1BADFISH™
« Reply #3 on: September 04, 2006 - 03:22:32 PM »
Yeah the 70-71 was the same, 72+ is different I think. I have a new one two and was just trying to figure at what screws to use as well...lol.
 :popcorn:
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
cudahob
« Reply #4 on: September 04, 2006 - 05:31:06 PM »
I looked it up in my 70 manual, because my memory is slipping.  :clueless:
Anyways they were screws.
Offline PlumCrazy
« Reply #5 on: September 04, 2006 - 06:04:42 PM »
Early 70 on top, late 70 and 71 bottom.
Offline widing'cuda
« Reply #6 on: September 04, 2006 - 11:28:42 PM »
what size are the screws?
