Author Topic: How do you get fine scratches out of glass?  (Read 1093 times)
Offline 70cudajim
« on: September 06, 2006 - 06:10:29 PM »
Topic says it all. What type of process can take out fine scratches? Anybody? Jim
Offline Total BS
  • '71 Carrabuda Baby!
Re: How do you get fine scratches out of glass?
« Reply #1 on: September 06, 2006 - 09:05:18 PM »
I bought a glass polishing kit from Eastwood.  It included a polishing powder and buffer and a wheel.  I haven't tried it yet but I have heard good things about it.  As long as you take your time it should work great.
1971 'Cuda 383
1970 Chevelle SS LS6
1999 Durango
-New Joisey-
Offline Carlwalski
« Reply #2 on: September 06, 2006 - 10:03:00 PM »
A razor blade also works well.  :thumbsup:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline 426 pentastar
« Reply #3 on: September 12, 2006 - 05:36:59 PM »
HHHmmm,never knew a razor blade would take out scratches from a glass surface????? But the buffing kit works great,the biggest thing is to keep it coated with the compound and moving.If you do stop in one place you can make a ripple in the glass.I have used the kit and its perfect,i would use a old peice of glass as a test bed.
71challengher
« Reply #4 on: September 12, 2006 - 05:42:38 PM »
toothpaste and a soft toothbrush
Offline Carlwalski
« Reply #5 on: September 12, 2006 - 07:24:31 PM »
It sure does! Give it a try next time, you'll be amazed.  :thumbsup:
Just tilt it on a 45 degree angle to the glass and softly but firmly "file" away at it.  :cheers:
