Author Topic: Idle Solenoid  (Read 724 times)
Offline trouble
Idle Solenoid
« on: September 07, 2006 - 03:50:06 PM »
 :clueless: I replaced my Idle Solenoid with a show quality one.Can someone tell me how it functions?Also is the screw above the solenoid suppose to push down on it.
thanks Al.
Re: Idle Solenoid
« Reply #1 on: September 07, 2006 - 04:51:33 PM »
it is design to hold the ide speed so yes the screw is supposed to rest on it , when the key is turned off the plunger in the solinoid drops down closing the throttle to prevent run on
Offline trouble
Re: Idle Solenoid
« Reply #2 on: September 13, 2006 - 07:19:46 PM »
 :clueless: I ordered a new solenoid,and when I was adjusting the bracket I broke off the front prong.When I pushed it back in,it would not work.Can this be fixed or do I have to purchase another one?
thanks Al.
Re: Idle Solenoid
« Reply #3 on: September 13, 2006 - 11:31:34 PM »
hard to say , pull off the rubber booot , it should be possible to resolder it in place , someone hed to build it originally , can`t be that hard to fix
 personally I never use them anywya so you could just stick the connector back it & it will still look correct
