Author Topic: Air Gap intake clearance  (Read 6395 times)
Offline Cuda72
  • Remember, in the next world you're on your own!
« on: September 07, 2006 - 06:27:26 PM »
I'm looking at getting a Performer Air Gap intake for my 340 Cuda (with rally hood) and I have some concerns about the clearance to the hood. Has anyone here run this intake on their Cuda with a normal Holley carb, and if so have you had any clearance issues with the stock rally hood?
Thanks,
Mark
Offline GoodysGotaCuda
Re: Air Gap intake clearance
« Reply #1 on: September 07, 2006 - 11:02:17 PM »
Thanks,
Mark
Well heres a 'for what its worth post'. I have a Performer RPM intake on my 318 (which is the exact same height as a AirGap), Edelbrock carb and a moroso Drop Base air cleaner with a 14x3" filter and it clears my FLAT hood. Rallye hood i think has another inch or clearance over a Flat i believe...
in short, it depends what filter/base setup you run, it'll clear..
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline EVIL72
« Reply #2 on: September 07, 2006 - 11:10:40 PM »
 Get a drop down base, I use a K&N one on my Challenger with a Holley DP and it sits down nice and low without any problems.
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #3 on: September 08, 2006 - 01:52:41 AM »
I have the non-airgap RPM on my 360 in my Challenger with r/t hood.  I do not have a drop base and my air filter cannot be more than 2 inches tall, but it does fit.
Offline bentpshrods
  • Almost there, Boise Id.
« Reply #4 on: September 08, 2006 - 10:34:20 PM »
  I have the performer air gap rpm manifold with a 770 holley  on my 340 cuda with the ralleye hood. I put a K&N 14x3 (stock base) on and it was just a little to tall  so I went to 14x3 with a dropped base and it fits with no problem.
Offline Cuda72
« Reply #5 on: September 11, 2006 - 06:08:39 PM »
Thanks for the input everyone! I picked up the RPM airgap while I was at Monster Mopar and if I can now find the time to install it I'll post my findings on what the clearance is (or is not) in my application. I just looked at the air cleaner I'm running right now and its a drop-base with a 3" element so I should be ok :clueless:
-Cuda72
(Mark)
Offline loco340cuda
« Reply #6 on: September 11, 2006 - 09:47:31 PM »
Cuda72, let me know how this goes.  I've been wanting to switch out my intake to the airgap but have been worried that it would not fit under the rallye hood.
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
« Reply #7 on: September 12, 2006 - 02:03:41 AM »
as mentioned i fit a performer rpm, which is the same height as a airgap, under my FLAT hood with just a drop base air cleaner...the rallye hoods have about a full inch more clearance than the flat hood i have. It should fit with no issue.  :cheers:
1976 Dodge Warlock
Offline loco340cuda
« Reply #8 on: September 13, 2006 - 06:41:43 AM »
Great, thanks for the info.  :thumbsup:
Offline 72brcda
  • death valley
« Reply #9 on: December 19, 2007 - 10:36:34 PM »
Do you know the model number of the K&N assembly? I just replaced my 318 with a 340 with an Air Gap manifold and am having hood clearance problems with my Moroso drop base air cleaner. I'd like to fix it right once (or twice) and would appreciate the input. I am using a Holley 670 Street Avenger aith the Air Gap intake. Thanks!
faster, faster
Offline MOPAR-or-NoCar73
« Reply #10 on: December 19, 2007 - 11:40:36 PM »
Like the others said, it should fit under the hood. I have Edelbrocks fuel injection system on my 318. I believe the manifold is a Super Victor, which I think is taller than the Air-Gap. I have a FLAT hood and  it barely fits under the hood. So you should not have a problem.
Here are some pics...
http://www.cuda-challenger.com/cc/index.php?topic=40035.0
Offline hemiken
« Reply #11 on: December 20, 2007 - 01:13:33 AM »
Hey G-man,
Early style 318-340-360 intakes were built with no gap under the runners totally different to that of a big block.  Know how big block intakes do not have a plate to close in the valley area and small blocks do have the plate intergrated into the intake.  New style small block and some of the older small intakes (single plain) had what is called an air-gap and this area under the intake is what determines an air-gap intake.
But in saying all that, Edelbrock have a Duel plain intake that is called an Air-gap as it also has the air-gap under the runners.
« Reply #12 on: December 20, 2007 - 01:28:52 AM »
the Big Block Dodge , early Hemi & pontiac engine were all designed with a cover plate on the block & intake runners raisedcreating the air gap to transmit less heat to the intake
Offline cudabob496
« Reply #13 on: December 20, 2007 - 02:08:29 AM »
To know how much room you have now, roll up balls of playdough and put them on your air filter, then close the hood. The playdough stays in the shape it was squished so you can measure your distance to the hood. Also, a 2 inch air filter may be hurting performance. I'd say a 3x14 K&N type is a minimum. Also, it's not expensive to have an eighth or quarter inch milled off the top of an intake, though you will probably find the right drop base. You can do other things like grind the inner flange of the drop base. By using playdough, and making a lot of minor Mods, I fit a 4x14 K&N in a Ram Air Box on my 72 Cuda.
http://ramairbox.com/bases.html
2011 Kawasaki Z1000
Offline 72brcda
  • death valley
« Reply #14 on: December 20, 2007 - 03:26:50 PM »
Thank you all for the responses. It seems my main problem with the drop base is clearing the choke, but with all the suggestions, I think I'll get the situation figured out. And also, it's been years and years since I've had a reason to buy playdough! Happy Holidays.
faster, faster
