Author Topic: panel removal  (Read 1044 times)
Offline 440_72cuda
panel removal
« on: September 07, 2006 - 06:28:53 PM »
i want to check the electrical connections behind the ammeter and i am having trouble getting at it. i have the cover to the gauges loose but cant remove it. does the dash have to come out or lower the steering column? i dont want to take apart more than i have to.  its a non rally dash if that makes any differance.
thanks Gord
Re: panel removal
« Reply #1 on: September 07, 2006 - 07:08:36 PM »
lower the steering column  I assume you have the light panel out as well
Offline 440_72cuda
Re: panel removal
« Reply #2 on: September 07, 2006 - 07:25:58 PM »
yes the lighting panel is removed.  is there much work to lower the steering column?
Re: panel removal
« Reply #3 on: September 07, 2006 - 11:13:08 PM »
3 nuts on two studs , 7/16  , & it will drop down , the studs are just under the dash
Offline ShelbyDogg
Re: panel removal
« Reply #4 on: September 08, 2006 - 08:34:37 AM »
Take out your headlight/wiper/dimmer switch panel first.
Offline 440_72cuda
Re: panel removal
« Reply #5 on: September 09, 2006 - 10:50:33 PM »
thanks guys i got it, and both leads were burnt.
Gord
