Where does the heating systen get it vacum from?
Author Topic: Where does the heating systen get it vacum from?  (Read 1751 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: September 09, 2006 - 04:20:27 PM »
The heating/ A/C system does not work on my 'cuda. As there in no vacum conected to the vacum system. I found a hole on the passenger side of the fire wall that has a vacum hose hanging out. Chould this be conected to the carburator somehow? I run a 750 Eddy carb. Anyone have map/ drawing of how it should be hooked up?
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Re: Where does the heating systen get it vacum from?
« Reply #1 on: September 09, 2006 - 05:48:28 PM »
The exact correct carb usually had an extra port on the rear for the A/C , it can be connected to the vacuum tree behind the carb in the intake
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #2 on: September 09, 2006 - 10:22:44 PM »
 :iagree:  That sounds like what I did.
Offline widing'cuda
« Reply #3 on: September 10, 2006 - 01:59:04 AM »
I don't have the original intake either. It's a Eddy Performer 383 intake. The only port I can find is meant for power brakes. Same on the rear side of the eddy carb. But the to vacuum port for the distributer in front, can I use any of those. As I don't have vacuum to my distrubuter (Mallory distrubuter)
« Reply #4 on: September 10, 2006 - 02:38:22 AM »
there are vacuum trees available with the port for the Power brakes & separate smaller ports for the heater etc , If you cannot find one someone from the US or Can can send you one
Offline 422STROKER
  • Member Since 6/3/06
« Reply #5 on: September 10, 2006 - 06:10:59 AM »
You need the manifold vacuum port on the carb, that should work until you can score a vac tree.  The tree is in the manifold so it has full vac all the time.  Check the instructions w/your new carb should show full/manifold port.
Good Luck
Tom
Tom
Offline widing'cuda
« Reply #6 on: September 17, 2006 - 04:33:14 PM »
I got the vacuum working using a port on the carb as a test. Where can I get a vacuum tree. Summit doesn't have them.  On that fit either the Edelbrock Performer 383 intake or 1/4" at the rear of the eddy carb. If soem one has a brand/ part number it easier for me to find it here in Norway
Offline Jacksboys
« Reply #7 on: September 18, 2006 - 01:22:44 PM »
I wish I had a part number for you, but the one I used was already on the engine when I rebuilt it.
Offline 422STROKER
« Reply #8 on: September 18, 2006 - 06:16:02 PM »
If you can't find one locally maybe you could source something from the local hardware store?  I might have something you could use but it would have lots of extra ports on it.  It's from a mid 70's 440 I had sometime back.  It's in my box o bolts!  They should have the single line adapter needed at the hardware store.  I'm not sure on the procedure to ship overseas but if it's the only choice let me know I'll dig it out and take a pic.
Good Luck
Tom :2thumbs:
Tom
Offline EaglesCall
« Reply #9 on: September 18, 2006 - 10:59:03 PM »
You might want to check eBay. There is one listed with a flattened port (the one you could use), but it does list a part number of 1944092. Run a search for "N96 VACUUM FITTING" . At least it gives you an idea. Good Luck !
'72 Satellite Sebring Plus
'72 Barracuda
'84 Dodge Rampage P/U
'99 Dodge Dakota SLT 4X4
