Author Topic: Engine clean up  (Read 1585 times)
Offline kingtroll
Engine clean up
« on: September 11, 2006 - 07:31:09 AM »
I was wondering does anybody have any suggestions on what to use to clean up engine compartment. What I mean is a spray to clean up valve covers and engine compartment to get off the accumulated crap that builds up on usage.
Thanks
1974 Barracuda
Offline heminut
Re: Engine clean up
« Reply #1 on: September 11, 2006 - 07:40:59 AM »
Gunk or Easy Off oven cleaner.
1970 5.7 Hemi Cuda
Offline kingtroll
Re: Engine clean up
« Reply #2 on: September 11, 2006 - 07:47:39 AM »
Thanks for the tip...:)
1974 Barracuda
Re: Engine clean up
« Reply #3 on: September 11, 2006 - 09:30:18 AM »
Gunk is pretty good at getting off the grease.  :grinyes:
Offline Grancoupe
Re: Engine clean up
« Reply #4 on: September 14, 2006 - 07:28:37 PM »
Cheap Oven Cleaner.
Offline 426 pentastar
Re: Engine clean up
« Reply #5 on: September 15, 2006 - 05:43:56 AM »
Try the new cleaner from easy-off,it wont take the paint off.
Offline kingtroll
Re: Engine clean up
« Reply #6 on: September 21, 2006 - 07:28:50 AM »
Taking the paint of definately would be a problem.... :22yikes:
1974 Barracuda
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Engine clean up
« Reply #7 on: September 21, 2006 - 07:32:27 AM »
Will that take off undercoating too?  :clueless:  Thanks!
Offline Cannibal94
Re: Engine clean up
« Reply #8 on: September 21, 2006 - 07:53:05 AM »
Q-tips, Toothbrush, Elbow Grease and Patience!!  :roflsmiley:
Be carefull with aftermarket valve covers, because I used something (don't remember what) and it took all of the finish off.  :hyper: Maybe test some small places before you do to much!  :2cents:
Re: Engine clean up
« Reply #9 on: September 21, 2006 - 07:59:26 AM »
I'll have to go to Auto Zone to get a tub of Elbow Grease.  Is that like white lithium?  :smilielol:
Re: Engine clean up
« Reply #10 on: September 21, 2006 - 08:13:12 AM »
It may not be the best product for removing undercoating but I believe it would soften it as undercoat is a carbon based product. If you are looking to dissolve undercoating I have found mineral spirits to be very effective.
UPDATE  It does not appear oven cleaner would be effective at removing undercoat. I just shot a spot & a couple of minutes & rubbing no undercoat came off, but it was very clean. I cannot speak for the long term effect. This was the "NO HEAT" Self Clean oven safe Easy Off.
« Last Edit: September 21, 2006 - 08:20:56 AM by bullitt99 »
Re: Engine clean up
« Reply #11 on: September 21, 2006 - 12:21:39 PM »
Cool, I'll check it out!  :thumbsup:
